> Puck for the horn, want dimensions
worn
post Sep 2 2024, 10:28 AM
can't remember
Hi all y'all,
I am getting tired of having my horn go off at inopportune moments because I have nudged the butterfly on the steering wheel by mistake. Ahh, a smooth sharp left turn with great savor faire an... blaaaaahhhhhhhhhhhhh, dammit.
So I want to be a cool kid and have a puck button. But not at that price! (insert eye watering emoji) And of course I make everything myself anyway. So could someone give me the OD and ID and height in and out? I can work it out from there. Might go with aluminum but also might go with ebony or rosewood from scraps that I have. Thanks so much. If necessary, I can bring calipers to RRC, but online would be better. That way I won't lose the scrap of paper I have them written on.
I know that there is a 3D printer file but I don't think that I could unravel it to get the measurements.
Thanks so much.
Warren
mlindner
post Sep 3 2024, 05:54 PM
Hi Worn, Mark from Merrimac. I need a horn puck just to cover the steering shaft nut...No logo, no chrome, no horn. I'll buy one of your early prototypes. Mark
worn
post Sep 3 2024, 09:45 PM
can't remember
QUOTE(mlindner @ Sep 3 2024, 04:54 PM) *
Thanks Mark. I will keep you in mind when I poke around in the exotic wood stockpile.
worn   Puck for the horn   Sep 2 2024, 10:28 AM
mepstein   4” ID at the base. The top tapers in a bit so ab...   Sep 2 2024, 10:49 AM
emerygt350   I had to make up my dimensions on that file anyway...   Sep 2 2024, 12:33 PM
worn   I had to make up my dimensions on that file anywa...   Sep 2 2024, 02:54 PM
mepstein   I had to make up my dimensions on that file anyw...   Sep 2 2024, 03:26 PM
worn   You can get a lot of the dimensions from your bat...   Sep 2 2024, 06:58 PM
porschetub   You can get a lot of the dimensions from your ba...   Sep 2 2024, 07:56 PM
worn   [quote name='worn' date='Sep 3 2024, ...   Sep 2 2024, 09:01 PM
mepstein   [quote name='worn' date='Sep 3 2024,...   Sep 3 2024, 05:07 AM
porschetub   [quote name='worn' date='Sep 2 2024, ...   Sep 3 2024, 01:29 PM
emerygt350   I can find the dimensions I used tomorrow morning....   Sep 2 2024, 05:35 PM
ConeDodger   Mine worked great! You had to treat it like an...   Sep 3 2024, 05:28 AM
emerygt350   Mine keeps you from hitting the horn and still loo...   Sep 3 2024, 05:48 PM
mlindner   Hi Worn, Mark from Merrimac. I need a horn puck ju...   Sep 3 2024, 05:54 PM
worn   Hi Worn, Mark from Merrimac. I need a horn puck j...   Sep 3 2024, 09:45 PM
emerygt350   My dimensions at the base are 100mm OD 95mm ID and...   Sep 4 2024, 09:56 AM
worn   My dimensions at the base are 100mm OD 95mm ID an...   Sep 4 2024, 07:22 PM
sixnotfour   OG :beer2: ,, Glad to have grown up in a Porsche r...   Sep 4 2024, 10:48 AM
emerygt350   nice. I am learning how to use lattice2 in freeca...   Sep 4 2024, 12:14 PM
emerygt350   it's getting there...   Sep 4 2024, 12:55 PM
worn   it's getting there... Nice. I like the pe...   Sep 4 2024, 07:24 PM
emerygt350   Here is my new draft... I will export it to a stl ...   Sep 5 2024, 11:18 AM
worn   Here is my new draft... I will export it to a stl...   Sep 5 2024, 05:23 PM
Ishley   I was wondering if a groove in the top would allow...   Sep 5 2024, 01:48 PM
emerygt350   I was wondering if a groove in the top would allo...   Sep 5 2024, 01:59 PM
Ishley   I’d cut the circle on a bandsaw and do the insid...   Sep 5 2024, 02:23 PM
emerygt350   The rabbit hole is deep... I am now learning how ...   Sep 5 2024, 06:05 PM
emerygt350   My brain is melting, but I am almost there...   Sep 6 2024, 10:14 AM
worn   My brain is melting, but I am almost there... ...   Sep 6 2024, 11:42 AM
emerygt350   This stuff is black magic. Makes me have a ton mo...   Sep 6 2024, 03:55 PM
Ishley   I contacted a friend of mine who does printing… ...   Sep 6 2024, 05:39 PM
emerygt350   That is really nice. I should update the files wi...   Sep 6 2024, 06:02 PM
emerygt350   Here is my attempt at leather texture... Now to se...   Sep 7 2024, 09:55 AM
emerygt350   slowly making progress...   Sep 13 2024, 07:07 AM
burton73   This is a real early 911 horn button on my 6. To g...   Sep 13 2024, 12:45 PM
emerygt350   This is a real early 911 horn button on my 6. To ...   Sep 13 2024, 03:41 PM
mepstein   This is a real early 911 horn button on my 6. To...   Sep 14 2024, 10:53 AM
emerygt350   but to get it for nothing on a 3d printer all you ...   Sep 13 2024, 01:25 PM
sixnotfour   Worn has an actual piece he did dimensioning off.....   Sep 14 2024, 09:45 AM
emerygt350   I have uploaded the most recent version. I have b...   Sep 23 2024, 10:46 AM
26 User(s) are reading this topic (26 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 4th January 2025 - 04:52 PM
