front wheel movement, Thought it was the bearings, but they are new... |
rjames |
Sep 4 2024, 12:28 AM
I'm made of metal Group: Members Posts: 4,171 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
After getting the newly rebuilt front suspension buttoned up, I thought I was done, but I can't seem to remove a bit of play in both of the front wheels. Feels exactly like loose wheel bearings, except that it's not. I installed new wheel bearings in the rotors even though the old ones looked fine since I was in there anyway. Spindles looked fine, too.
I verified no movement in the strut, and I can't feel any movement anywhere else on the strut assembly (ball joint, tie rods, control arm etc.). Over tightening the bearings only helped a tiny bit, (I didn't drive on the overtightened bearing, just did it to see if it removed the play). I've done my front bearings before and didn't run into this issue. I guess I'm left with removing the rotors, but don't even know what to look for. |
arbitrary |
Sep 4 2024, 07:28 AM
Member Group: Members Posts: 95 Joined: 25-April 21 From: UK Member No.: 25,475 Region Association: None |
Worn spindles? Check them with a micrometer.
rjames |
Sep 4 2024, 07:49 AM
Lo-Fi Version | Time is now: 15th January 2025 - 07:39 AM |
