Pedal Cluster Rubber Base Mat, Part Number or Material Source |
DennisV |
Sep 5 2024, 07:10 AM
Senior Member Group: Members Posts: 551 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California |
Does anyone recognize this thin rubber mat found under the pedal cluster that can offer a part number? Ours is breaking down.
I looked in the PDF parts catalog and searched on vendor sites but can't find a part number. Alternatively, is there a material source that I can cut my own? Thank you. |
Craigers17 |
Sep 5 2024, 10:04 AM
Senior Member Group: Members Posts: 805 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
When I pulled the pedal cluster out of a 74" that I used to have, this was several years ago, there was a piece under the pedal cluster as well. I have attached a couple of pics, and even though it looks like it's metal, if I recall correctly, it too was made of a rubbery compound. (in the pic, it looks suspiciously like the piece of metal that was removed for the master cylinder hole, but they weren't the same size.
The reason I believe it was made of rubber(even though it looks rusty), is that I replaced it with a couple of sheets of "Flex Tape". You can see on the floorboard where it sat beneath the pedal cluster. I cannot say for certain that the pedal cluster had never been removed, but it sure looked original. |
Lo-Fi Version | Time is now: 28th November 2024 - 03:37 AM |
