Solvent HELP, Cannot find solvent to dissolve adhesive |
Gatornapper |
Sep 3 2024, 06:31 PM
Senior Member Group: Members Posts: 1,263 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
I love the black leather Dino steering wheel that is on my 944 S.
I want to put it on my 914. So I got a tan Dino steering wheel to go in my 944 S that has a tan interior. One problem - I can find no solvent to remove the adhesive from the new tan steering wheel. It had clear plastic protecting the chrome which pulled off easily. But I can find no solvent to dissolve the adhesive that held the clear plastic on. I have tried gasoline, strong carb cleaner, brake cleaner, acetone, lacquer thinner, WD-40, Seafoam, and even Super Glue Remover. I can't take the nice wheel out of the 944 S until the new one can go in. HELP. Looking for advice on a solvent that will dissolve this adhesive. Pics below - many thanks to all suggestions. GN (IMG:http://www.914world.com/bbs2/uploads_offsite/hosting.photobucket.com-21449-1725409879.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/hosting.photobucket.com-21449-1725409879.2.JPG) |
914sgofast2 |
Sep 5 2024, 10:45 AM
Senior Member Group: Members Posts: 656 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
Have you tried Simple Green cleaner? Put some on the adhesive and let it soak into the adhesive for a few minutes before you start rubbing it. Use an old bathroom cotton towel because it is slightly rougher than using an old cotton t-shirt.
The metal on the steering wheel is likely polished aluminum, not chromed steel. You could try polishing out the scratches from the pumice-based hand cleaner with some 0000 steel wool. |
Lo-Fi Version | Time is now: 2nd January 2025 - 09:41 AM |
