front wheel movement, Thought it was the bearings, but they are new... |
rjames |
Sep 4 2024, 12:28 AM
I'm made of metal Group: Members Posts: 4,171 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
After getting the newly rebuilt front suspension buttoned up, I thought I was done, but I can't seem to remove a bit of play in both of the front wheels. Feels exactly like loose wheel bearings, except that it's not. I installed new wheel bearings in the rotors even though the old ones looked fine since I was in there anyway. Spindles looked fine, too.
I verified no movement in the strut, and I can't feel any movement anywhere else on the strut assembly (ball joint, tie rods, control arm etc.). Over tightening the bearings only helped a tiny bit, (I didn't drive on the overtightened bearing, just did it to see if it removed the play). I've done my front bearings before and didn't run into this issue. I guess I'm left with removing the rotors, but don't even know what to look for. |
Superhawk996 |
Sep 6 2024, 07:13 AM
914 Guru Group: Members Posts: 6,663 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Did you measure spindles & Bearings?
The fact that it seems worse with weight on it needs to be followed up on. Things affected by having weight and/or ride height differences: Bearings (are you sure races are fully seated)? Sorry to ask since you have over tightened bearing and removed rotors, but are you absolutely sure? Did you remove grease and actually look at race position within the rotor? Strut gland nut - The Koni strut cartridge may be seating further into strut housing creating play at the top gland nut at curb ride height. Tie rod ends. Seems to me that I recall you having some “extra” clearance between those Koni strut rods and the top body mount ? Maybe I’m not remembering correctly? If it were me I’d start measuring the play with a dial indicator to know how much play there is and to see where it’s coming from. Example: dial indicator mounted between body and the top of the strut rod to see if that extra clearance at the top strut mount is showing up. |
Lo-Fi Version | Time is now: 15th January 2025 - 07:33 AM |
