front wheel movement, Thought it was the bearings, but they are new... |
rjames |
Sep 4 2024, 12:28 AM
I'm made of metal Group: Members Posts: 4,171 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
After getting the newly rebuilt front suspension buttoned up, I thought I was done, but I can't seem to remove a bit of play in both of the front wheels. Feels exactly like loose wheel bearings, except that it's not. I installed new wheel bearings in the rotors even though the old ones looked fine since I was in there anyway. Spindles looked fine, too.
I verified no movement in the strut, and I can't feel any movement anywhere else on the strut assembly (ball joint, tie rods, control arm etc.). Over tightening the bearings only helped a tiny bit, (I didn't drive on the overtightened bearing, just did it to see if it removed the play). I've done my front bearings before and didn't run into this issue. I guess I'm left with removing the rotors, but don't even know what to look for. |
rjames |
Sep 6 2024, 07:10 PM
I don’t have a micrometer, only calipers, so my measurements may have not been accurate enough.
I also don’t have the patience to pull the struts assembly off again, try and source another set and cross my fingers that they aren’t jacked, too. Going to try and forget I own this car for the rest of the weekend, which will be difficult since I was supposed to take it to a local car show on Sunday. I normally enjoy working on the car, but the front end was a big undertaking/time suck and I hit a bunch of stupid self-inflicted roadblocks. Now that I know my way around it, disassembling would be much quicker, I just don’t have it in me at the moment. I’m still perplexed how both spindles could be bad. I guess I can try and order another set of bearings and hope for a different outcome. Thanks for all the help everyone. |
Lo-Fi Version | Time is now: 15th January 2025 - 07:44 AM |
