Cross roads between a big /4 and a big/6, Share your experience |
Montreal914 |
Sep 5 2024, 08:31 AM
Senior Member Group: Members Posts: 1,742 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
I am at a cross road in my narrow body restoration project. This is not an original build, but rather a sleeper 914 with nice elements. The chassis will be reinforced with an inner kit and outer RD clamshell.
The car will be converted to 5 lugs using the right 3" 911 struts/hubs and drilled rear hubs. The braking system is Alfa Brembo calipers in the front and 914-6 reproduction rears with appropriate 19mm MC. Sport Bilstein all around and 140 rear springs. Front 19mm and std rear sway bar. Wheels will either be Fuchs 15" x 6" or 16" x 6". I have no intentions of shoehorning 7" wide wheels in the back, no fender stretching. My engine options are as follow: I have all the nice bits to build a 2.3 4 cylinder (HAM heads, Nickies, rods, crank, block with large studs, Tangerine headers, yadi yada...). I would setup a modern EFI to it and should conservatively get 150-160 HP out of it. I have an opportunity to get a 3.2 Motronic 6 cylinder, 200+ HP. I plan on using a 901 gearbox and I already have the Tarett heavy duty CV/shafts kit. Although it may seem obvious that the desired option would be to go with the six, again, this is a narrow body with 6" wide wheels. My concern is the drastic amount of power and the additional mass on this car's configuration. A while back I remember reading a comment from Pete Stout @horizontally-opposed , where I recall him saying somethnig like he felt the 914 has a better balance with a 4 cylinder engine, but he was willing to make that tradeoff to have the sound, smoothness and pleasure of a 6 cylinder. That being said, his beautiful car (reference narrow body in my book (IMG:style_emoticons/default/wub.gif) ) is equipped with a small 2.2 six. I have some engine weight data that looks like this: 4 cylinder: ~321lbs 2.4 six cylinder: ~400 3.2 six cylinder: ~485lbs I have never riden let alone driven a 6 cylinder powered 914, but I do have 10 years of daily California canyon driving mine (4 cylinder 2056). I know how the 4 cylinder car feels and I can probably picture how it would drive with a large /4. I would like to hear what people have experience with their narrow bodied 3.2 conversion (I am sure there must be some), and what they prefer, their old 4 or their new six. I appreciate and value all of your comments! (IMG:style_emoticons/default/smilie_pokal.gif) Thank you, Eric |
Montreal914 |
Sep 7 2024, 05:05 PM
Great! A couple of options on the table, PMS and custom Terry cable. (IMG:style_emoticons/default/sunglasses.gif) Duly noted, thank you! (IMG:style_emoticons/default/pray.gif)
Things are really starting to shape up here! (IMG:style_emoticons/default/smile.gif) |
930cabman |
Sep 7 2024, 05:20 PM
Advanced Member Group: Members Posts: 3,834 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Great! A couple of options on the table, PMS and custom Terry cable. (IMG:style_emoticons/default/sunglasses.gif) Duly noted, thank you! (IMG:style_emoticons/default/pray.gif) Things are really starting to shape up here! (IMG:style_emoticons/default/smile.gif) The PMS throttle cable did work, with modification. The core was about 1 1/2" too long. PMS did not reply to my request regarding this, what else is new. In the future I will contact the folks at Terry Best of luck with your build, which ever road you take |
Lo-Fi Version | Time is now: 15th January 2025 - 07:47 AM |
