> Cross roads between a big /4 and a big/6, Share your experience
Montreal914
post Sep 5 2024, 08:31 AM
I am at a cross road in my narrow body restoration project. This is not an original build, but rather a sleeper 914 with nice elements. The chassis will be reinforced with an inner kit and outer RD clamshell.
The car will be converted to 5 lugs using the right 3" 911 struts/hubs and drilled rear hubs. The braking system is Alfa Brembo calipers in the front and 914-6 reproduction rears with appropriate 19mm MC. Sport Bilstein all around and 140 rear springs. Front 19mm and std rear sway bar.
Wheels will either be Fuchs 15" x 6" or 16" x 6". I have no intentions of shoehorning 7" wide wheels in the back, no fender stretching.
My engine options are as follow:
I have all the nice bits to build a 2.3 4 cylinder (HAM heads, Nickies, rods, crank, block with large studs, Tangerine headers, yadi yada...). I would setup a modern EFI to it and should conservatively get 150-160 HP out of it.
I have an opportunity to get a 3.2 Motronic 6 cylinder, 200+ HP.
I plan on using a 901 gearbox and I already have the Tarett heavy duty CV/shafts kit.
Although it may seem obvious that the desired option would be to go with the six, again, this is a narrow body with 6" wide wheels. My concern is the drastic amount of power and the additional mass on this car's configuration.
A while back I remember reading a comment from Pete Stout @horizontally-opposed , where I recall him saying somethnig like he felt the 914 has a better balance with a 4 cylinder engine, but he was willing to make that tradeoff to have the sound, smoothness and pleasure of a 6 cylinder. That being said, his beautiful car (reference narrow body in my book (IMG:style_emoticons/default/wub.gif) ) is equipped with a small 2.2 six.
I have some engine weight data that looks like this:
4 cylinder: ~321lbs
2.4 six cylinder: ~400
3.2 six cylinder: ~485lbs
I have never riden let alone driven a 6 cylinder powered 914, but I do have 10 years of daily California canyon driving mine (4 cylinder 2056). I know how the 4 cylinder car feels and I can probably picture how it would drive with a large /4.
I would like to hear what people have experience with their narrow bodied 3.2 conversion (I am sure there must be some), and what they prefer, their old 4 or their new six.
I appreciate and value all of your comments! (IMG:style_emoticons/default/smilie_pokal.gif)
Thank you,
Eric
Montreal914
post Sep 7 2024, 05:05 PM
Great! A couple of options on the table, PMS and custom Terry cable. (IMG:style_emoticons/default/sunglasses.gif) Duly noted, thank you! (IMG:style_emoticons/default/pray.gif)
Things are really starting to shape up here! (IMG:style_emoticons/default/smile.gif)
wndsrfr
post Sep 7 2024, 07:22 PM
QUOTE(Montreal914 @ Sep 7 2024, 03:05 PM) *
901 Shop in Florida has a very direct straight shot cable system. Literally straight from the gas pedal through the firewall to the throttle cross bar. I can't remember the price but it's excellent for my track car. Call for Brady there..772-781-2944 and he'll send you pics.
That said, I've tried the backside loop approach after getting failures of the "coat hanger". I found that the factory system has a lot going for it in terms of progressive action at partial throttle movement which is the majority of street driving plus it provides full open WOT action when set up properly. The geometry of the bellcrank at the rear of the transmission allows slow opening of the throttle plates during first 25% of gas pedal movement then progressively faster for the rest of travel to WOT. So if you're wanting good street manners I vote for the factory system---BUT getting the correct coat hanger part is a PITA...
Montreal914   Cross roads between a big /4 and a big/6   Sep 5 2024, 08:31 AM
dr914@autoatlanta.com   if you want a six, keep the stock fenders and inst...   Sep 5 2024, 09:02 AM
technicalninja   Get 16" wheels! Way more options for tir...   Sep 5 2024, 09:05 AM
Chris914n6   First, I'd go 16 for the better tire choices. ...   Sep 5 2024, 09:11 AM
SirAndy   I think the sweet spot for the 914 is a 3.2L /6 wi...   Sep 5 2024, 10:44 AM
sixnotfour   I think the sweet spot for the 914 is a 3.2L /6 w...   Sep 5 2024, 10:49 AM
MoveQik   I think the sweet spot for the 914 is a 3.2L /6 w...   Sep 6 2024, 08:20 AM
ConeDodger   I think the sweet spot for the 914 is a 3.2L /6 w...   Sep 22 2024, 11:02 AM
Montreal914   Very good inputs so far. :) Although I prefer t...   Sep 5 2024, 11:42 AM
ClayPerrine   I have had a 2.0L four, a 2.4L six and a 4.0L six ...   Sep 5 2024, 12:00 PM
JamesJ   http://www.914world.com/bbs2/index.php?showtopic=3...   Sep 5 2024, 12:07 PM
mepstein   I’ll agree with sir Andy about a 3.2 being the p...   Sep 5 2024, 12:13 PM
mepstein   One more thing. There’s nothing wrong with using...   Sep 5 2024, 12:17 PM
Root_Werks   I would vote for the 3.2 for reasons already state...   Sep 5 2024, 12:45 PM
Cairo94507   I have had a few original 914-6's. I had a st...   Sep 5 2024, 12:48 PM
burton73   As far as the engines go I have a six and I went t...   Sep 5 2024, 12:55 PM
Eric_Shea   :agree: with Bob. The "Deep Six" and ...   Sep 5 2024, 02:23 PM
mepstein   :agree: with Bob. The "Deep Six" and ...   Sep 5 2024, 07:00 PM
Shivers   :agree: with Bob. The "Deep Six" and ...   Sep 6 2024, 04:17 PM
horizontally-opposed   The "Deep Six" and "7R" is ...   Sep 8 2024, 01:07 PM
Eric_Shea   The "Deep Six" and "7R" is ...   Sep 9 2024, 06:48 PM
gereed75   There are great replies here. Between this thread...   Sep 5 2024, 02:45 PM
rhodyguy   Swell looking ‘new’ intake configuration. Is i...   Sep 5 2024, 03:01 PM
rjames   :rotfl:   Sep 5 2024, 03:08 PM
930cabman   :popcorn: Great discussion here everyone :pop...   Sep 5 2024, 03:32 PM
JmuRiz   If you have the 2.3 /4 parts, go for it. Brother ...   Sep 5 2024, 03:49 PM
seanpaulmc   Seems like the choice is clear - you need a second...   Sep 5 2024, 05:25 PM
Montreal914   Seems like the choice is clear - you need a secon...   Sep 5 2024, 05:34 PM
Montreal914   Yes, this is a good turnout of information. I real...   Sep 5 2024, 05:32 PM
mepstein   [quote name='Montreal914' date='Sep 5 ...   Sep 5 2024, 07:16 PM
gereed75   Wow. Really cool Eric.   Sep 5 2024, 07:10 PM
VaccaRabite   Second year with the EFI 2.3 /4. I really like it...   Sep 6 2024, 05:24 AM
IronHillRestorations   I’m a fan of 3.0’s and 3.2’s with Motronic, ...   Sep 6 2024, 12:08 PM
Montreal914   Found some good threads an info in the garage. I ...   Sep 6 2024, 01:53 PM
ClayPerrine   Found some good threads an info in the garage. I...   Sep 6 2024, 05:03 PM
Montreal914   Found some good threads an info in the garage. ...   Sep 6 2024, 05:20 PM
Chris914n6   5/16 - 8mm is sufficient. Looks like you've ...   Sep 7 2024, 01:35 AM
mb911   Well I personally have never driven a big 4 so can...   Sep 7 2024, 05:41 AM
gereed75   I have a factory six with the stock accelerator li...   Sep 7 2024, 06:45 AM
mepstein   If you do a simple cable, you just have to make su...   Sep 7 2024, 07:24 AM
Montreal914   @Chris914n6 thank you for the info on the fuel li...   Sep 7 2024, 08:33 AM
mepstein   I think the linkage affects the ratio of pedal tra...   Sep 7 2024, 09:30 AM
echocanyons   I have a hot 3.2 wide body and my son has a hot 2....   Sep 7 2024, 10:11 AM
930cabman   I think the linkage affects the ratio of pedal tr...   Sep 7 2024, 11:45 AM
Montreal914   I think the linkage affects the ratio of pedal t...   Sep 7 2024, 02:06 PM
tomeric914   My reasons for going with a 6 nearly 15 years ago ...   Sep 7 2024, 11:41 AM
mepstein   I’m pretty sure @sirAndy used a PMS cable on h...   Sep 7 2024, 02:46 PM
SirAndy   I’m pretty sure [b]@[url=http://www.914world.c...   Sep 7 2024, 04:10 PM
Cairo94507   I used the PMS throttle cable on my 3.6 conversion...   Sep 7 2024, 03:22 PM
tomeric914   https://www.terrycable.com/Throttle-cable-f...otor...   Sep 7 2024, 03:32 PM
Montreal914   Great! A couple of options on the table, PMS a...   Sep 7 2024, 05:05 PM
930cabman   Great! A couple of options on the table, PMS ...   Sep 7 2024, 05:20 PM
wndsrfr   Great! A couple of options on the table, PMS ...   Sep 7 2024, 07:22 PM
Montreal914   Great! A couple of options on the table, PMS...   Sep 8 2024, 08:18 AM
horizontally-opposed   A while back I remember reading a comment from Pe...   Sep 8 2024, 01:27 PM
seanpaulmc   @Montreal914 congrats and Godspeed on the Six con...   Sep 22 2024, 10:53 AM
Montreal914   Quick update to share that yes, I got the 3.2 with...   Sep 22 2024, 02:19 PM
23 User(s) are reading this topic (23 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 15th January 2025 - 07:52 AM
