front wheel movement, Thought it was the bearings, but they are new... |
rjames |
Sep 4 2024, 12:28 AM
I'm made of metal Group: Members Posts: 4,171 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
After getting the newly rebuilt front suspension buttoned up, I thought I was done, but I can't seem to remove a bit of play in both of the front wheels. Feels exactly like loose wheel bearings, except that it's not. I installed new wheel bearings in the rotors even though the old ones looked fine since I was in there anyway. Spindles looked fine, too.
I verified no movement in the strut, and I can't feel any movement anywhere else on the strut assembly (ball joint, tie rods, control arm etc.). Over tightening the bearings only helped a tiny bit, (I didn't drive on the overtightened bearing, just did it to see if it removed the play). I've done my front bearings before and didn't run into this issue. I guess I'm left with removing the rotors, but don't even know what to look for. |
mepstein |
Sep 7 2024, 07:51 PM
914-6 GT in waiting Group: Members Posts: 19,702 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
You never over tighten bearings. You can permanently damage bearings by making them too tight. You seat the races with the proper tool and then adjust the bearing until it’s smooth and without play. Then check it (no wiggle or play) after a good drive or two.
rjames |
Sep 7 2024, 09:29 PM
You never over tighten bearings. You can permanently damage bearings by making them too tight. You seat the races with the proper tool and then adjust the bearing until it’s smooth and without play. Then check it (no wiggle or play) after a good drive or two. I hear you, I’m just pointing out that it’s not exactly straightforward to determine if you’re over tightening it. I forgot to add that Haynes manual says to tighten the nut until you can gently push the washer with a screwdriver. That sounds much different than anything quoted above, but that’s what I’ll start with going forward. |
mepstein |
Sep 7 2024, 09:33 PM
You never over tighten bearings. You can permanently damage bearings by making them too tight. You seat the races with the proper tool and then adjust the bearing until it’s smooth and without play. Then check it (no wiggle or play) after a good drive or two. I hear you, I’m just pointing out that it’s not exactly straightforward to determine if you’re over tightening it. I forgot to add that Haynes manual says to tighten the nut until you can gently push the washer with a screwdriver. That sounds much different than anything quoted above, but that’s what I’ll start with going forward. Not a bad rule of thumb |
Lo-Fi Version | Time is now: 15th January 2025 - 07:34 AM |
