Found disconnected wires - Going where? |
PaIsa |
Sep 8 2024, 07:57 AM
Member Group: Members Posts: 86 Joined: 13-June 24 From: Quebec, Canada Member No.: 28,180 Region Association: Canada |
Literati914 |
Sep 9 2024, 12:53 PM
Senior Member Group: Members Posts: 1,799 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
It looks like a brown/white wire ... does your horn work? There is a BR/WH from the steering column switch to the horn Relay (at the 85 spot)- not sure if that's it but look at items #26 and #51 in the wiring diagram. No idea why it would be over by your reservoir though .. Horn in perfect working condition. OK, then what about the parking brake contact and the seatbelt warning lights that illuminate at the combo gauge - those wires are BR/WH and I think they tie into each other. .. well, also the master cylinder has a BR/WH wire too as well, that lights at the same place in the combo gauge (+ an all brown one) for the 'Brake warning light switch'. That might make more since from where those wires are. |
Lo-Fi Version | Time is now: 15th January 2025 - 06:59 AM |
