> Leaded or unleaded - That's the question, Need advice on which type of fuel to use..
reineg
post Sep 16 2024, 06:31 AM
Region Association: Europe
Hi there, Laymen and Experts alike!
I have recently acquired a 914/4-70 with a newly built engine. Up to 2.2litre and some extra horses to boot. But now to the question:
The car has got new cylinders and pistons from Pelican Parts, but I do not know much more about the engine. So do you guys (and gals) reckon it would be safer to use modern fuel and add lead, or shall I just go for modern fuel and not add lead?
What is most detrimental to the engine; to add lead to an engine that doesn't need it, or not to add lead to an engine that requires it?
Appreciate any and all thoughts on this..
GregAmy
post Sep 16 2024, 08:01 AM
I can't imagine any heads rebuilt in the last 30 years needing lead (to protect the valve seats).
And I can't imagine any engine built for the street needing lead (for octane) especially when you can get 110 unleaded racing fuel (if needed). Honestly, street engines should be built to safely handle 93 octane max (91 if that's what's typically in your region).
Lead isn't pleasant stuff but it should not hurt your engine, even if it doesn't need it. But leaded fuel can have its own problems such as precipitating out if it evaporates from non-use. The photo below is the main jet stack from the Dells in my race car, photo taken earlier this month. For whatever reason (I think it was cheaper) I bought 112 Leaded at an event in June instead of 100 Unleaded, and then parked the car after the weekend. When I pulled it out the week before Memorial Day to get it ready for an event that weekend, it was running like hell...and this was why.
Ask your engine builder for minimum fuel specs, but I just don't see any rational reason to need leaded fuel these days. - GA
930cabman
post Sep 16 2024, 08:11 AM
QUOTE(GregAmy @ Sep 16 2024, 08:01 AM) *
Ouch, what happened to this main jet/holder? Probably water (IMG:style_emoticons/default/screwy.gif)
reineg   Leaded or unleaded - That's the question   Sep 16 2024, 06:31 AM
VaccaRabite   No one in the states adds lead. You should be per...   Sep 16 2024, 06:37 AM
reineg   No one in the states adds lead. You should be pe...   Sep 16 2024, 06:45 AM
914Sixer   NON ethanol gas is my preferred choice. Burns cle...   Sep 16 2024, 07:51 AM
reineg   NON ethanol gas is my preferred choice. Burns cl...   Sep 16 2024, 08:54 AM
GregAmy   I can't imagine any heads rebuilt in the last ...   Sep 16 2024, 08:01 AM
930cabman   I can't imagine any heads rebuilt in the last...   Sep 16 2024, 08:11 AM
GregAmy   Ouch, what happened to this main jet/holder? Proba...   Sep 16 2024, 08:34 AM
dr914@autoatlanta.com   regular unleaded is just fine Hi there, Laymen...   Sep 16 2024, 12:02 PM
Jamie   I switched my stock 1.7L over 2 yrs. ago to non-et...   Sep 16 2024, 12:29 PM
wonkipop   Hi there, Laymen and Experts alike! I have r...   Sep 16 2024, 06:57 PM
Superhawk996   but by the time we get to the 90s the fuel comp...   Sep 16 2024, 07:23 PM
wonkipop   but by the time we get to the 90s the fuel com...   Sep 16 2024, 09:37 PM
bkrantz   But the challenge the OP has with a modified 2.2 l...   Sep 16 2024, 09:31 PM
wonkipop   But the challenge the OP has with a modified 2.2 ...   Sep 16 2024, 09:40 PM
Dave_Darling   probably needs highest octane unleaded available....   Sep 17 2024, 03:42 PM
wonkipop   probably needs highest octane unleaded available...   Sep 17 2024, 04:12 PM
reineg   Seems you all agree on running unleaded, and I wil...   Sep 17 2024, 12:51 AM
technicalninja   Is leaded gas or real lead additives available in ...   Sep 17 2024, 07:54 AM
wonkipop   Is leaded gas or real lead additives available in...   Sep 17 2024, 04:17 PM
reineg   Is leaded gas or real lead additives available in...   Sep 18 2024, 12:25 AM
brant   The lubrication of lead is real Some motors had to...   Sep 17 2024, 04:28 PM
wonkipop   The lubrication of lead is real Some motors had t...   Sep 17 2024, 05:27 PM
reineg   The lubrication of lead is real Some motors had t...   Sep 18 2024, 12:27 AM
- Lo-Fi Version Time is now: 26th April 2025 - 03:11 AM
