What could have I done?, Car is running on only 2 and 3. |
robkammer |
Sep 15 2024, 12:47 PM
Member Group: Members Posts: 200 Joined: 7-January 21 From: Vermilion Ohio Member No.: 25,049 Region Association: North East States |
All: In prepping our BB for the vintage event next week I have done the following, along with a couple of fellow cult members. I had experienced a rather jolting banging at the right rear corner only in fifth gear. Between us, we diagnosed this as a transmission issue.
Pulled the tranny and took it to the good Doctor last week. He pulled it apart and found nothing major, only some minor wear items that he replaced. Once back in the shop I looked more closely at the CV's.They were dry and binding badly. This was the problem. Ordered rebuilt's from George and installed them, when they FINALLY arrived. All good, so we thought. Got the axles in, wheels on, lowered the car and fired it up. Runs like , uh, crap. Pulled the disty cap, Ok, new cap, rotor and points should do it. Nah. Pulled plug wires 3#4, no change. It is running on 1#2 only. Pulled #4 plug, beautiful. a nice shade of tan. Put a timing light on all four plug wires, all are getting juice. Called John at Air cooled Plus to see if there was any possibility that his flywheel work could be the cause. Nope. He did grab a Bosch manual and alert us to a second set of contact points in the distributor, below the ignition points, that fire the injectors. Who knew? Pulled the disty, cleaned the FI points, all good. Still running on 1&2. Fellow cult member Jeff had a spare FI box and distributor, swapped boxes, no change. Pulled the FI points and tested continuity and they are performing just as the points in the car are, and also test the same. Good continuity between the disty trigger contact and injector contacts on all four cylinders Errlier, while I was waiting for parts, I did de-A/C the car. Pulled the condenser, receiver dryer, the underdash console and all of the hoses. Installed a correct tall console. I needed to pull some of the derelict wiring from the engine bay through the console to complete the process. I left the compressor in until I pull the engine this winter. It all went well without any drama. At least I thought so I can't think of anything in the passenger compartment that would affect the FI. We were only working in the back, pulling the transaxle and axle shafts. What could we possibly have touched to kill the two cylinders? Any input would be welcome. At this point I'm relegated to taking another car to the event. Cheers! Rob |
Jack Standz |
Sep 16 2024, 04:03 PM
Member Group: Members Posts: 433 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None |
Very good theory and practice. Thanks for suggesting it.
But, when you pull out the multimeter to see if you're getting voltage or continuity along that path/circuit, you turn it on and nothing. Then you go get some "fresh" batteries for the meter, but, when you try to open the case it's a very small screw that you need to find a very small screwdriver, you go to dig it out from your old tool box, but then you remember you were using that particular screw driver to fix your glasses and it's at the office. You finally get the screw loose (maybe a grinder, if you can remember where you left it) and put the batteries in and, nothing. So, you need a multimeter to test if the "fresh" batteries are flat or is that old meter you've dropped maybe half a million times, is now broken? After returning from the store with your new multimeter and a "few" extra tools, you've now completely forgotten what you needed to go to the store to get a multimeter for in the first place or even what a half-split methodology was or is. You then repeatedly curse the DAPOs and buy an entire new wiring harness for your 50+ year old Porsche 914 'cause you're sick of half-splitting electrical problems on crusty virtually useless wiring that's been hacked up by half-ass*d, half-witted DAPOs, who don't know what a half-split troubleshooting process is. If I had half a mind, that's exactly what I'd do. YMMV. Oh, and good luck with the fix. It does sound electrical. |
Lo-Fi Version | Time is now: 15th January 2025 - 09:30 AM |
