Voltage drop problem |
jvmarino |
Sep 5 2024, 07:38 PM
Member Group: Members Posts: 96 Joined: 22-March 09 From: Baltimore Member No.: 10,188 Region Association: None |
Driving the 914 today I noticed an issue with voltage drop for the first time. Car starts up fine, runs good as usual, but when rpm goes over about 3600, the volt gauge has a noticeable drop down to about 12v indicated. Generator light also comes on. When rpm goes back below 3600, light turns off and volt gauge jumps back up about 1.5 volts.
My initial thought was a loose alternator belt, as I haven’t touched it since rebuilding car almost 30 years ago. Felt the belt and it seemed too slack. So tonight I tackled this project and after about an hour of cursing at the lower 13mm bolt, I finally found a way to loosen it. I get the belt tightened and button everything back up. Fire car up and it still does the same volt drop thing. Anyone here have any thoughts on what the problem is. Car still drives fine, but I don’t want to take it anywhere until this is solved as it would stink if it completely dies on me while using it. Jim |
jvmarino |
Sep 17 2024, 12:22 PM
I am by no means an expert on car charging systems. It seems the more I read about troubleshooting them, the more confusing it gets with possible problems. I did see some other internet discussions where people mentioned these same symptoms that was due to worn brushes in the alternator. It is odd that the light comes on and the volt meter reading drops like a switch when I hit that magic RPM level, and then it reverses when the rpm comes back down below that level.
Really dreading having to take it out of the car. Just tightening up the belt was a major PIA as the pivot bolt nut was nearly impossible to get a tool on. Also finding that there are no rebuilt units available to purchase. I need to see if there are any good shops in the Baltimore area to rebuild an alternator. This is one of those times when you appreciate the simplicity of a front engine and a vehicle with lots of parts available. On the other hand, I guess 50 years from an alternator is pretty good. |
Spoke |
Sep 18 2024, 11:43 AM
Jerry Group: Members Posts: 7,106 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
was due to worn brushes in the alternator. It almost sounds like this is the issue. I had a '74 Dodge Colt (Mitsubishi) and it stopped charging on a long drive. I stopped to check things and at idle it would charge. Rev the engine and charging stopped. Pulled the alternator and put my ohmmeter across the armature. Spun the alternator by hand and observed the resistance increase then decrease as the armature slowed down. Brushes were well worn. Cleaned the brushes and the commutator rings and all was good. Do the full field test by pulling the VR and shorting D+ to DF. Measure both battery voltage and D+ voltage at different RPMs. |
Lo-Fi Version | Time is now: 5th January 2025 - 01:47 AM |
