> cast aluminum valve covers
Tom_in_NH
post Sep 18 2024, 09:26 AM
Perpetually leaking valve covers on an otherwise dry motor have driven me nuts. I've used the rubber gaskets, cork gaskets. no sealer, with sealer.........
So, I'm now looking at cast aluminum valve covers, as I believe their rigidity and milled surfaces will solve the issue.
Any experience or manufacturer recomendations?
Tom
brant
post Sep 19 2024, 12:19 PM
My experience with cast aluminum was good
Most say the are bad
Mine worked on a race -4 for ten years
We had already tightened the stock bales and frequently blew the gasket out from high rpm. Suspected too much pressure from very high rpm race motor. Went aluminum and solved our problem
You should tighten your stock bales before giving up on stock
They should work fine for street use below 7k
Tom_in_NH   cast aluminum valve covers   Sep 18 2024, 09:26 AM
windforfun   I've heard that they don't work that much ...   Sep 18 2024, 09:59 AM
JeffBowlsby   Logos installed upside down on the stock metal cov...   Sep 18 2024, 10:03 AM
Tom_in_NH   I have checked them for flatness last time they we...   Sep 18 2024, 12:11 PM
JeffBowlsby   I have checked them for flatness last time they w...   Sep 18 2024, 12:31 PM
Tom_in_NH   Ah yes. I just found the Raby reference to logo or...   Sep 18 2024, 12:51 PM
technicalninja   I have checked them for flatness last time they w...   Sep 18 2024, 01:38 PM
GregAmy   I use the cast bolt-on covers on my higher-revving...   Sep 18 2024, 03:20 PM
windforfun   I was just under the car & for the life of me,...   Sep 18 2024, 04:07 PM
ClayPerrine   I have always put them on with the logo right side...   Sep 18 2024, 04:41 PM
emerygt350   I wonder how many of you are running positive cran...   Sep 18 2024, 05:46 PM
Tom_in_NH   @GregAmy , Do you remember if your valve covers ar...   Sep 18 2024, 05:49 PM
GregAmy   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Sep 18 2024, 08:35 PM
rgalla9146   I've never seen a cast aluminum valve cover th...   Sep 18 2024, 06:16 PM
Jack Standz   We use and like the Empi ones with silicone rubber...   Sep 18 2024, 10:21 PM
Tom_in_NH   @GregAmy , I think Scat is the manufacturer of the...   Sep 19 2024, 09:40 AM
GregAmy   I think Scat is the manufacturer of the aluminum c...   Sep 19 2024, 08:35 PM
brant   My experience with cast aluminum was good Most sa...   Sep 19 2024, 12:19 PM
Eric_Ciampa   Check the valve cover for flatness. I have had the...   Sep 20 2024, 12:58 AM
- Lo-Fi Version Time is now: 15th January 2025 - 05:36 AM
