Nor.Cal.914 |
1975 914 3.0SC ![]() ![]() ![]() Group: Members Posts: 1,062 Joined: 28-January 05 From: Weatherford, TX Member No.: 3,523 Region Association: None ![]() |
Hello everyone,
I have a 1974 1.8L that needs a new fuel pump and the customer purchased this pump from Pelican: https://www.pelicanparts.com/More_Info/0439...59&DID=4630 I have already figured out the line routing in terms of inlet and outlet, but I do have a few questions about some other aspects. Being that the stock pump is a 3-port pump, first question is, what was the reasoning behind the 3 ports instead of just an inlet and outlet? My first thought was maybe an internal FPR, but I see there is a one in the engine compartment so that doesn't seem to be the case, but please correct me if I'm wrong! Second question involves mounting the pump. I have a 1975 so I'm not as familiar with how the 1974's were setup. This car has the coil style ring bracket around the pump which I'm now trying to figure out if I can utilize to mount the new pump. Main issue of course is the fact that all 3 lines came out on one side of the factory pump, whereas this pump has inlet/outlet on either side. So my question is, what have you guys done to mount your pumps either in the same location or where did you place it instead of the factory location? Thank you in advance for the help! (IMG:style_emoticons/default/beerchug.gif) -Christopher |
Geezer914 |
Geezer914 ![]() ![]() ![]() Group: Members Posts: 1,912 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States ![]() ![]() |
Get a Delphi pump from Rock Auto for $108!
Nor.Cal.914 |
Get a Delphi pump from Rock Auto for $108! This was the customer's choice for pump, but yes, I would've gone for a cheaper option myself! (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 30th April 2025 - 11:34 AM |
