> NEED HELP: 1974 1.8L Will Only Start with Brake Clean, Runs with AFM disconnected only
Nor.Cal.914
post Sep 19 2024, 03:03 PM
1975 914 3.0SC
Hello everyone,
I have a 1974 1.8L that needs a new fuel pump and the customer purchased this pump from Pelican:
https://www.pelicanparts.com/More_Info/0439...59&DID=4630
I have already figured out the line routing in terms of inlet and outlet, but I do have a few questions about some other aspects. Being that the stock pump is a 3-port pump, first question is, what was the reasoning behind the 3 ports instead of just an inlet and outlet? My first thought was maybe an internal FPR, but I see there is a one in the engine compartment so that doesn't seem to be the case, but please correct me if I'm wrong! Second question involves mounting the pump. I have a 1975 so I'm not as familiar with how the 1974's were setup. This car has the coil style ring bracket around the pump which I'm now trying to figure out if I can utilize to mount the new pump. Main issue of course is the fact that all 3 lines came out on one side of the factory pump, whereas this pump has inlet/outlet on either side.
So my question is, what have you guys done to mount your pumps either in the same location or where did you place it instead of the factory location? Thank you in advance for the help! (IMG:style_emoticons/default/beerchug.gif)
-Christopher
wonkipop
post Sep 19 2024, 05:10 PM
and yes you will have a bit of trouble mounting a modern turbine pump in the stock location under the right hand side of the engine bay in a 74. most of the pumps are a bit too long in length.
the issue will be the loop the supply fuel line has to make to get into the top of the pump.
if you can even get a satisfactory slow curve. which i doubt. and if you did it would likely give you trouble with collapsing. producing symptoms like the dread vapor lock problem of legend. but slightly different of course.
i had a turbine 2 port pump mounted in mine while i was rebuilding. i mounted it on the rear wall of the engine side of the passenger compartment. fire wall. this i believe was an earlier location for 3 port pumps in the first few model years. that let me get the lines in and out without any tight curves. later when i reinstalled my rebuilt 3 port i could put it all back in using the original mounting location.
can i suggest if you use a modern rotary fuel pump that you include a high pressure fuel filter in the line after the pump. you can usually mount in the engine bay in line before it gets to the injectors. the original roller cell pumps are real tough dependable units and unlikely to blow themselves apart internally. but modern fuel pumps are another matter.
the last thing you want is pump implosion debris getting to the fuel injectors these days, given they are getting a bit hard to get hold of in some cases.
Nor.Cal.914   NEED HELP: 1974 1.8L Will Only Start with Brake Clean   Sep 19 2024, 03:03 PM
Geezer914   Get a Delphi pump from Rock Auto for $108...   Sep 19 2024, 03:37 PM
Nor.Cal.914   Get a Delphi pump from Rock Auto for $108...   Sep 19 2024, 03:57 PM
Artfrombama   Get a Delphi pump from Rock Auto for $108...   Sep 19 2024, 04:02 PM
wonkipop   have rebuilt two of the old bosch 3 port pumps. li...   Sep 19 2024, 04:52 PM
Nor.Cal.914   have rebuilt two of the old bosch 3 port pumps. l...   Sep 23 2024, 08:45 AM
wonkipop   and yes you will have a bit of trouble mounting a ...   Sep 19 2024, 05:10 PM
wonkipop   postscript. went back and re-read my own thread t...   Sep 19 2024, 05:47 PM
dr914@autoatlanta.com   we sell the conversion kit for 125.00 that include...   Sep 23 2024, 08:47 AM
Nor.Cal.914   we sell the conversion kit for 125.00 that includ...   Sep 23 2024, 09:29 AM
StarBear   Weird that it runs only with the AFM disconnected....   Sep 23 2024, 09:55 AM
Nor.Cal.914   Weird that it runs only with the AFM disconnected...   Sep 23 2024, 10:49 AM
Artfrombama   Forgive me if you have already done this but have ...   Sep 23 2024, 11:50 AM
Nor.Cal.914   Forgive me if you have already done this but have...   Sep 23 2024, 03:33 PM
wonkipop   here is what i think. a few us here with 1.8s hav...   Sep 23 2024, 05:22 PM
Nor.Cal.914   here is what i think. a few us here with 1.8s ha...   Oct 7 2024, 03:06 PM
Nor.Cal.914   Here are some pictures of the engine bay. If there...   Oct 7 2024, 03:15 PM
Nor.Cal.914   Last one:   Oct 7 2024, 03:15 PM
wonkipop   @[url=http://www.914world.com/bbs2/index.php?showu...   Oct 7 2024, 05:25 PM
fiacra   A few thoughts that came to mind when reading your...   Oct 7 2024, 06:30 PM
wonkipop   here is a direct link to the L jet troubleshooting...   Oct 7 2024, 09:28 PM
wonkipop   ok @[url=http://www.914world.com/bbs2/index.php?s...   Oct 7 2024, 09:53 PM
wonkipop   looking close at one of your photos. something see...   Oct 7 2024, 10:24 PM
L-Jet914   That caught my attention too @wonkipop the wire ...   Oct 7 2024, 10:56 PM
wonkipop   That caught my attention too [b]@[url=http://www...   Oct 8 2024, 12:30 AM
wonkipop   i just noticed another thing. the fuse board or wh...   Oct 8 2024, 01:03 AM
Nor.Cal.914   A few thoughts that came to mind when reading you...   Oct 8 2024, 08:33 AM
wonkipop   @[url=http://www.914world.com/bbs2/index.php?showu...   Oct 8 2024, 04:17 PM
wonkipop   Some other things I found this morning while testi...   Oct 8 2024, 10:52 PM
technicalninja   Hello from Granbury Texas! I have a shitload ...   Oct 8 2024, 08:59 AM
Nor.Cal.914   Hello from Granbury Texas! I have a shitload...   Oct 8 2024, 09:14 AM
technicalninja   My units have 7 pins! Check your connector tha...   Oct 8 2024, 09:53 AM
technicalninja   If the fuel is poisoned, you have to clear that fi...   Oct 8 2024, 10:59 AM
technicalninja   MOST IMPORTANT TIP!!!!!!...   Oct 8 2024, 11:13 AM
Nor.Cal.914   My units have 7 pins! Check your connector th...   Oct 8 2024, 02:58 PM
Artfrombama   Is the fuel injection trigger wire connected to th...   Oct 8 2024, 06:31 PM
- Lo-Fi Version Time is now: 30th April 2025 - 11:37 AM
