Tom Perso |
Crazy from the Cold... ![]() ![]() ![]() Group: Members Posts: 647 Joined: 8-August 03 From: Kalamazoo, MI Member No.: 1,003 ![]() |
Hey Guys,
I am designing a MS system for my 2270 (163.86b cam, 48x38 valves, future Triad header). I am looking at running stock intake runners and possibly making a new plenum to run my Ford TB (probably from a 4.0L Exploder/Ranger). Are there any "design guidelines" that should be followed when making a new plenum, such as a certian volume required for engine displacement? Looking at space requirements, I see running the TB on top of the plenum is the only way to go. That, of course - begs the question... Is the stock 914 2.0L plenum a good starting point to modify to allow for the Ford TB? Here are some pics for reference... I had a Bus 2.0L intake system to borrow, so I am basing my measurements and ideas off of that. http://www.qtm.net/~persot/MS/ Any ideas, suggestions, etc, are appreciated! Thanks, Tom |
Reiche |
Member ![]() ![]() Group: Members Posts: 169 Joined: 13-October 04 From: Vista, CA Member No.: 2,934 ![]() |
Those seem like huge numbers to me. I think I read on another thread that the stock plenum is a bit less than the engine total displacement. If you keep close to the same ratios you would only need a plenum size of about 1.8 liters or so and a TB of about 50–55 mm. Obviously the cam will play a huge role in the exact numbers but Dave got his to work with a stock plenum. |
Lo-Fi Version | Time is now: 26th April 2025 - 02:48 AM |
