rfinegan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,067 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region ![]() ![]() |
I have been narrowing down the Root Cause on a misfire 73 2.0 D jet. Cold it hits on all 4 but as it warms up I have a miss. Compression a little low but may be washed down rings. 10% leak down/ seem to seal up ok.
When I disconnect the injector no change. Plug back in no change Noid light check for pulse PASS Spark getting to the plug PASS. Change plug anyhow as it was new and unknown state Gut tells me I have an injector acting odd Today I ran the same basic test: I had a good idle but fast, 1300-1500. Figured I has hitting on 4 now...I pulled the wire off the injector and the speed went UP.. plugged back in and the speed went back down. WTF NEXT STEP: 1) add fuel gage and confirm pressure ; adjust regulator as needed ( fuel Line kink has been fixed (was lean) pressure base line unknown 2) swap injectors 3/4 see if problem follows to Cly 3. (best) Or put a different injector in Cyl 4 and test for new behavior (lazy) Other: I borrowed my 123 Distribute and installed in the 73 2.0 to base line an ignition problem (jumping Tach) Root Cause was a Coil installed backwards. Smoke machine test shows no Vacuum leaks. Ever so slight leak at throttle shaft, but feels great Curious as to see if others feel that injector is off in the weeds? Sticking and now leaking? |
Lockwodo |
Member ![]() ![]() Group: Members Posts: 213 Joined: 23-December 21 From: Santa Cruz, Californnia Member No.: 26,193 Region Association: Northern California ![]() ![]() |
You may be right about the problem being related to a dodgy injector and to get at that I prefer the "best" approach.
Is the distributor stock? I wonder if shaft looseness or trigger point issues could contribute to misfires? If you still have the 123 disty you could try swapping that back in and see if the misfire issue goes away. |
rfinegan |
YES, The 123 is in right now and clean things up to let me find the #4 dropping out.
I have a set of 4 spare injectors but state unknown. I also have my running 75 Djet I have been pulling test parts from for diagnostics. Its on stand getting new SS fuel lines so it only my time..low/no cost Thanks for the feedback, I will have some details soon You may be right about the problem being related to a dodgy injector and to get at that I prefer the "best" approach. Is the distributor stock? I wonder if shaft looseness or trigger point issues could contribute to misfires? If you still have the 123 disty you could try swapping that back in and see if the misfire issue goes away. |
Lo-Fi Version | Time is now: 29th April 2025 - 07:33 AM |
