Help me set up these Webers, Basic Weber questions |
MikeK |
Sep 27 2024, 01:06 PM
Member Group: Members Posts: 132 Joined: 15-June 23 From: 80906 Member No.: 27,418 Region Association: Rocky Mountains |
Hi friends. I'm currently installing some Weber clones on my 70 and have run into some issues. I'm using a CB linkage and filter bases. I tried installing the carbs with the linkage to the rear of the car, but the drop links hit the torsion springs used on the trunk. I flipped the bases so the crossbar is towards the front of the car, but the linkage needs to rotate counter-clockwise (see photo) in order to operate the carbs. I guess I could run the throttle arm on the top of the linkage and pull it that way, but I would prefer the arm to be in the down position. I was thinking maybe a custom cable which would be longer and come in from the back or perhaps some kind of lever to reverse the rotation?
I don't know, but I'm sure this has been dealt with in the past. Just looking for an elegant solution. As a side note, tall air cleaners most definitely don't fit the passengers side. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.thesamba.com-27418-1727464006.1.jpg) Thanks in advance. |
Jack Standz |
Sep 28 2024, 01:32 AM
Member Group: Members Posts: 418 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None |
Move the bracket on the cross bar to something like this one (or get just get shorter intake manifolds):
http://www.914world.com/bbs2/lofiversion/i...php?t43028.html Scroll down the thread in the post to see several options. However, I agree with the other posters that the Tangerine Racing solution is a lot better (once you go through the pain of installing it, as it's not a simple bolt-on part). No longer use cross bar linkage. |
Lo-Fi Version | Time is now: 22nd December 2024 - 04:38 PM |
