Help me set up these Webers, Basic Weber questions |
Thursday, 9 January 2025 |
MikeK |
Sep 27 2024, 01:06 PM
Member Group: Members Posts: 132 Joined: 15-June 23 From: 80906 Member No.: 27,418 Region Association: Rocky Mountains |
Hi friends. I'm currently installing some Weber clones on my 70 and have run into some issues. I'm using a CB linkage and filter bases. I tried installing the carbs with the linkage to the rear of the car, but the drop links hit the torsion springs used on the trunk. I flipped the bases so the crossbar is towards the front of the car, but the linkage needs to rotate counter-clockwise (see photo) in order to operate the carbs. I guess I could run the throttle arm on the top of the linkage and pull it that way, but I would prefer the arm to be in the down position. I was thinking maybe a custom cable which would be longer and come in from the back or perhaps some kind of lever to reverse the rotation?
I don't know, but I'm sure this has been dealt with in the past. Just looking for an elegant solution. As a side note, tall air cleaners most definitely don't fit the passengers side. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.thesamba.com-27418-1727464006.1.jpg) Thanks in advance. |
technicalninja |
Sep 27 2024, 08:08 PM
Advanced Member Group: Members Posts: 2,232 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
Unless you've changed them the carbs come with too large a primary venturi.
Even a 2.0l benefits from 28s over 32s. If you're smaller, it's even more important. Pierce manifolds is a good source for parts and linkage. If you're running 40s, they have venturis as small as 27. https://www.piercemanifolds.com/ I'd start with venturis 28, mains 130-135, air correction 190-200, Emulsion tubes F11 and pilots 50-55. You have the tall manifolds and there are others that are shorter. The air filters might fit on a short version... |
MikeK |
Sep 28 2024, 08:34 AM
Unless you've changed them the carbs come with too large a primary venturi. Even a 2.0l benefits from 28s over 32s. If you're smaller, it's even more important. Pierce manifolds is a good source for parts and linkage. If you're running 40s, they have venturis as small as 27. https://www.piercemanifolds.com/ I'd start with venturis 28, mains 130-135, air correction 190-200, Emulsion tubes F11 and pilots 50-55. You have the tall manifolds and there are others that are shorter. The air filters might fit on a short version... The standard jetting and venturis supplied with the carbs area good starting point. It has 28mm venturis. These carbs were about $75 each on Ebay. I've gone through them, set the floats to 12mm, checked jet sizes, lube and lock-tighted everything and reassembled. The only complaints that I have so far is that the emulsion tubes are drilled perpendicular to the tube and not at an angle, like OG Webers are. I'm going to give it a try and worst case scenario is that I stick in some new F11's. Here's what it came with: 200 Air correction F11 Emulsion tubes 115 Mains 50 Idles |
Lo-Fi Version | Time is now: 8th January 2025 - 09:24 PM |
