Help me set up these Webers, Basic Weber questions |
MikeK |
Sep 27 2024, 01:06 PM
Member Group: Members Posts: 132 Joined: 15-June 23 From: 80906 Member No.: 27,418 Region Association: Rocky Mountains |
Hi friends. I'm currently installing some Weber clones on my 70 and have run into some issues. I'm using a CB linkage and filter bases. I tried installing the carbs with the linkage to the rear of the car, but the drop links hit the torsion springs used on the trunk. I flipped the bases so the crossbar is towards the front of the car, but the linkage needs to rotate counter-clockwise (see photo) in order to operate the carbs. I guess I could run the throttle arm on the top of the linkage and pull it that way, but I would prefer the arm to be in the down position. I was thinking maybe a custom cable which would be longer and come in from the back or perhaps some kind of lever to reverse the rotation?
I don't know, but I'm sure this has been dealt with in the past. Just looking for an elegant solution. As a side note, tall air cleaners most definitely don't fit the passengers side. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.thesamba.com-27418-1727464006.1.jpg) Thanks in advance. |
930cabman |
Sep 28 2024, 08:45 AM
Advanced Member Group: Members Posts: 3,777 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
I have several hex bar linkage setup's on the shelf, couldn't get any of them to work correctly. IIRC the geometry was kicking my a**. I fabricated a simple setup with a couple of 3/16" rods, couplers and ends. Works perfect, doesn't look so much, but I have been running it for a couple years now. 2056 twin Weber 40's
generally smaller is better when getting started out with carbs |
Lo-Fi Version | Time is now: 22nd December 2024 - 04:33 PM |
