Voltage drop problem |
jvmarino |
Sep 5 2024, 07:38 PM
Member Group: Members Posts: 96 Joined: 22-March 09 From: Baltimore Member No.: 10,188 Region Association: None |
Driving the 914 today I noticed an issue with voltage drop for the first time. Car starts up fine, runs good as usual, but when rpm goes over about 3600, the volt gauge has a noticeable drop down to about 12v indicated. Generator light also comes on. When rpm goes back below 3600, light turns off and volt gauge jumps back up about 1.5 volts.
My initial thought was a loose alternator belt, as I haven’t touched it since rebuilding car almost 30 years ago. Felt the belt and it seemed too slack. So tonight I tackled this project and after about an hour of cursing at the lower 13mm bolt, I finally found a way to loosen it. I get the belt tightened and button everything back up. Fire car up and it still does the same volt drop thing. Anyone here have any thoughts on what the problem is. Car still drives fine, but I don’t want to take it anywhere until this is solved as it would stink if it completely dies on me while using it. Jim |
jvmarino |
Oct 5 2024, 01:27 PM
Well I finally got around to some testing after some delays. First I jumpered DF to D+, hooked meter to battery and started car. Voltage started above 14v and running rpm up over 4K the voltage went up over 18v. I then removed jumper and plugged VR back in and car was running about 13.6v and at high rpm dropped down between 13.1 & 13.3. The GEN light still came on at high rpm’s.
Did not do what I thought it would when using the jumper. Any thoughts from those with better experience than me? |
Lo-Fi Version | Time is now: 5th January 2025 - 01:25 AM |
