Brake Lights, FIXED TODAY |
jim_hoyland |
Oct 5 2024, 05:59 PM
Get that VIN ? Group: Members Posts: 9,556 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
While working on an unrelated issue, I lost the brake lights.
Fuse on #9 is good, how does the brake pedal switch activate the stop lights ? Need to know where to start…… |
jim_hoyland |
Oct 5 2024, 06:33 PM
How is the switch wired, I’m looking to see where it goes
bdstone914 |
Oct 5 2024, 07:47 PM
bdstone914 Group: Members Posts: 4,731 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@jim_hoyland
' post='3171371' date='Oct 5 2024, 05:33 PM'] How is the switch wired, I’m looking to see where it goes [/quote] They rarely fail. Do you have power at fuse 9 ? What wiring issue were you working on as it sound like it is related. With ignition on, one of the wires at the switch should have power. I would first check for power at the brake light socket then the wire into the housing. I use a stick to depress and hold the pedal down if a helper is not available. If all checks out there then move to the pedals. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 22nd December 2024 - 05:28 AM |
