Nor.Cal.914 |
1975 914 3.0SC ![]() ![]() ![]() Group: Members Posts: 1,062 Joined: 28-January 05 From: Weatherford, TX Member No.: 3,523 Region Association: None ![]() |
Hello everyone,
I have a 1974 1.8L that needs a new fuel pump and the customer purchased this pump from Pelican: https://www.pelicanparts.com/More_Info/0439...59&DID=4630 I have already figured out the line routing in terms of inlet and outlet, but I do have a few questions about some other aspects. Being that the stock pump is a 3-port pump, first question is, what was the reasoning behind the 3 ports instead of just an inlet and outlet? My first thought was maybe an internal FPR, but I see there is a one in the engine compartment so that doesn't seem to be the case, but please correct me if I'm wrong! Second question involves mounting the pump. I have a 1975 so I'm not as familiar with how the 1974's were setup. This car has the coil style ring bracket around the pump which I'm now trying to figure out if I can utilize to mount the new pump. Main issue of course is the fact that all 3 lines came out on one side of the factory pump, whereas this pump has inlet/outlet on either side. So my question is, what have you guys done to mount your pumps either in the same location or where did you place it instead of the factory location? Thank you in advance for the help! (IMG:style_emoticons/default/beerchug.gif) -Christopher |
wonkipop |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,753 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille ![]() ![]() |
@Nor.Cal.914
this link will get you started. you can download the factory workshop manuals for the 914. you only need group 2 four cylinder fuel injection volume. http://p914-6info.net/Manuals.htm it can be a bit confusing as all the D jet stuff is mixed in there. the way these factory manuals worked i gather is they issued them at the introduction of the car and then as the model years progressed added sections in. so the L jet stuff is scattered through out though it is mostly concentrated at the end. there are some test procedures for each component in the L jet EFI. but not everything is there. i have some other stuff which is VW L jet troubleshooting guides which apply to the type 4 VWs. pretty close to the same system as in 914. and i think somewhere else diagrams for testing the dual relays and ECU harness and plugs etc. but i have to dig them up. will post later. |
Lo-Fi Version | Time is now: 30th April 2025 - 11:30 AM |
