914ltd |
Member ![]() ![]() Group: Members Posts: 243 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None ![]() ![]() |
Nice rear sway bar mounts replicating the factory pieces. $60 for the 1970-1974 and $40. for the 1975 and 1976 cars.
Attached thumbnail(s) ![]() ![]() Attached image(s) ![]() ![]() |
Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,812 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
If you car is a 73 and did not have the brackets, it is a 1.7.
Sway bars appeared on 914-4 in 73 as standard on the 2.0. They were then optional after. The brackets you should be using are the stepped ones (Z shape). The flat ones are for the 75-76 cars because that area of the rear is different due to the shock absorbers of the impact bumpers (also known as BUB, big ugly bumpers). Good luck with your installation! (IMG:style_emoticons/default/smash.gif) |
cassmcentee |
Member ![]() ![]() Group: Members Posts: 225 Joined: 12-July 18 From: Squaw Valley, CA Member No.: 22,304 Region Association: Central California ![]() ![]() |
If you car is a 73 and did not have the brackets, it is a 1.7. Sway bars appeared on 914-4 in 73 as standard on the 2.0. They were then optional after. The brackets you should be using are the stepped ones (Z shape). The flat ones are for the 75-76 cars because that area of the rear is different due to the shock absorbers of the impact bumpers (also known as BUB, big ugly bumpers). Good luck with your installation! (IMG:style_emoticons/default/smash.gif) Thank you! She's getting a 2+ dropped in, or rather, "Lifted In" (IMG:style_emoticons/default/smoke.gif) ![]() |
Lo-Fi Version | Time is now: 29th April 2025 - 07:29 AM |
