D-Jet Conversion not going as planned., Car starts but will not run. |
slapshot |
Oct 18 2024, 03:08 PM
Member Group: Members Posts: 109 Joined: 11-June 23 From: Utah Member No.: 27,409 Region Association: Rocky Mountains |
I am converting back to D-Jet and my car will start but dies right after. It will not rev up applying throttle. I have a 1975 914 2.0. It was running great with Weber 40s prior.
The D-Jet system is from a 1974 2.0. All the parts came in visibly good condition. TPS calibrates good, AAV tested good, Thermo sensor good, air intake temp sensor good, and a new cylinder head temp sensor. The only test that I think is failing is the vacuum test on the MPS. It leaks. Video of testing the MPS.. The MPS has also been rebuilt at some point. The original part # has been removed. There's a good chance it is not calibrated for my car. I have all new vacuum hose and fuel pressure is between 28 and 30. I don't have any tools to calibrate the MPS. Should I try turning the inner screw on the MPS to see if it helps? Or should I send it to someone to have it rebuild again and recalibrated? If the later do you have any recommendations on who to send it to? |
TheCabinetmaker |
Oct 18 2024, 05:42 PM
I drive my car everyday Group: Members Posts: 8,320 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Do you hear the fuel pump come on for a half second when you turn the key to "on"? That primes the pump so you can start it. As soon as it's running, the ECU takes over to provide power to the pump. It's connected by a fuse and relays on the relay board. It's very rare, but ECUs do fail!
Lo-Fi Version | Time is now: 28th November 2024 - 05:05 AM |
