Free. Just pay shipping, Gas Strut kit for rear trunk |
ClayPerrine |
Oct 25 2024, 05:11 PM
Life's been good to me so far..... Group: Admin Posts: 16,065 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I pulled the gas struts off the 914-6. I am taking it back to stock, so I am giving away the gas strut kit that was on it. All the parts, including nuts and bolts are there. The struts are worn out, but they come with it so you should be able to match them to a set from your FLAPS.
If you use this, you have to cut the pinch weld between the engine compartment and the trunk to clear the struts. Clay |
vintage914racer |
Oct 25 2024, 05:38 PM
Member Group: Members Posts: 454 Joined: 28-December 03 From: Minneapolis, MN Member No.: 1,473 |
I pulled the gas struts off the 914-6. I am taking it back to stock, so I am giving away the gas strut kit that was on it. All the parts, including nuts and bolts are there. The struts are worn out, but they come with it so you should be able to match them to a set from your FLAPS. If you use this, you have to cut the pinch weld between the engine compartment and the trunk to clear the struts. Clay I'll take them if still available. |
Lo-Fi Version | Time is now: 5th February 2025 - 02:07 PM |
