D-Jet Conversion not going as planned., Car starts but will not run. |
slapshot |
Oct 18 2024, 03:08 PM
Member Group: Members Posts: 109 Joined: 11-June 23 From: Utah Member No.: 27,409 Region Association: Rocky Mountains |
I am converting back to D-Jet and my car will start but dies right after. It will not rev up applying throttle. I have a 1975 914 2.0. It was running great with Weber 40s prior.
The D-Jet system is from a 1974 2.0. All the parts came in visibly good condition. TPS calibrates good, AAV tested good, Thermo sensor good, air intake temp sensor good, and a new cylinder head temp sensor. The only test that I think is failing is the vacuum test on the MPS. It leaks. Video of testing the MPS.. The MPS has also been rebuilt at some point. The original part # has been removed. There's a good chance it is not calibrated for my car. I have all new vacuum hose and fuel pressure is between 28 and 30. I don't have any tools to calibrate the MPS. Should I try turning the inner screw on the MPS to see if it helps? Or should I send it to someone to have it rebuild again and recalibrated? If the later do you have any recommendations on who to send it to? |
slapshot |
Oct 25 2024, 09:12 PM
I do have a 123 dizzy so no dwell to mess with and I have vacuum advance disabled.
I don't know what else to check to find TDC #1. I set the fan wheel to the timing mark, did a leak down to verify that the valves were closed on #1 and even opened the valve cover and verified #1 rocker arms where both loose. Oh and I did a leak down on #3 to verify that exhaust valve was open. Anything else to check? I'll disconnect the TPS tomorrow and take it for another spin. I just got back from a ride, it cut out at least once as I would get on the throttle. Not as I would get on the throttle but some point as RPMs were increasing. It seems to run cooler than before but that's base only on two short rides. |
Lo-Fi Version | Time is now: 28th November 2024 - 04:39 AM |
