D-Jet Conversion not going as planned., Car starts but will not run. |
slapshot |
Oct 18 2024, 03:08 PM
Member Group: Members Posts: 109 Joined: 11-June 23 From: Utah Member No.: 27,409 Region Association: Rocky Mountains |
I am converting back to D-Jet and my car will start but dies right after. It will not rev up applying throttle. I have a 1975 914 2.0. It was running great with Weber 40s prior.
The D-Jet system is from a 1974 2.0. All the parts came in visibly good condition. TPS calibrates good, AAV tested good, Thermo sensor good, air intake temp sensor good, and a new cylinder head temp sensor. The only test that I think is failing is the vacuum test on the MPS. It leaks. Video of testing the MPS.. The MPS has also been rebuilt at some point. The original part # has been removed. There's a good chance it is not calibrated for my car. I have all new vacuum hose and fuel pressure is between 28 and 30. I don't have any tools to calibrate the MPS. Should I try turning the inner screw on the MPS to see if it helps? Or should I send it to someone to have it rebuild again and recalibrated? If the later do you have any recommendations on who to send it to? |
emerygt350 |
Oct 26 2024, 05:46 AM
Advanced Member Group: Members Posts: 2,485 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I use a boroscope to ensure tdc, but what you did works too. Idle is set at 3400 if I remember correctly (double check that). My car really likes 28.5 but each car is different. Since we have 123s I am not certain that old way of setting idle is really necessary. I find 8ish at idle equals where I want to be all in. However, if your idle is high you are stuck doing the high rpm timing anyway.
I am not familiar with setting the curve in Bluetooth dizzys but I do know there are some suggested curves to start with for d-jet. If you are getting a miss and your timing is good I would suspect mps tuning at that point. You probably have lean spots at particular vacuum rpm combinations. Do you have afr gauge set up? I found having a vacuum gauge and an afr in the cab allowed me to tune the mps relatively easily in the car. Oh, and if you have bad spots in your TPS, the whole engine stops (the ECU seems to stop the injectors or something). Like a whole engine miss. It's really disturbing and only tends to happen when you are cruising (that's where the bad spot develops). |
Lo-Fi Version | Time is now: 28th November 2024 - 04:49 AM |
