914/6 Stubs & SC Hubs, Good Condition - PRICE DROP |
gcrotvik |
Oct 28 2024, 08:36 AM
Member Group: Members Posts: 361 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
Set of 914/6 stub axles and 911SC hubs. This combination provides 5 lug hubs for 914/6 or 6 conversions with hub-centering (HUB CENTRIC). The 901 hubs are not hub centric. You will need a set of 5MM spacers to make these fit a 914 trailing arm correctly. The spacers are available through Patrick Motorsports. See link and picture below.
https://patrickmotorsports.com/products/dri...7b3a2&_ss=r $350.00 for the set, shipped in the conus (not including PMS spacers). No on-line (PayPal, etc.) payments. Check or cashier's check please. Attached image(s) |
dug |
Oct 28 2024, 01:08 PM
Member Group: Members Posts: 183 Joined: 26-December 06 From: Santa Cruz, CA Member No.: 7,382 Region Association: Northern California |
Curious...
Does this move the hub flange out 5mm from the trailing arm? Does that eliminate the need to use a 5mm spacer under a 911 brake rotor, or 5mm washer between the brake caliper and hub? |
mepstein |
Oct 28 2024, 01:24 PM
914-6 GT in waiting Group: Members Posts: 19,578 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Curious... Does this move the hub flange out 5mm from the trailing arm? Does that eliminate the need to use a 5mm spacer under a 911 brake rotor, or 5mm washer between the brake caliper and hub? It just makes the bearing sit correctly/space correctly in the later hubs. |
gcrotvik |
Oct 28 2024, 01:25 PM
Curious... Does this move the hub flange out 5mm from the trailing arm? Does that eliminate the need to use a 5mm spacer under a 911 brake rotor, or 5mm washer between the brake caliper and hub? It just makes the bearing sit correctly/space correctly in the later hubs. Thank you Mark. Well said in shorter words! |
Lo-Fi Version | Time is now: 1st November 2024 - 04:18 AM |
