914/6 Stubs & SC Hubs, Good Condition - PRICE DROP |
gcrotvik |
Oct 28 2024, 08:36 AM
Member Group: Members Posts: 361 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
Set of 914/6 stub axles and 911SC hubs. This combination provides 5 lug hubs for 914/6 or 6 conversions with hub-centering (HUB CENTRIC). The 901 hubs are not hub centric. You will need a set of 5MM spacers to make these fit a 914 trailing arm correctly. The spacers are available through Patrick Motorsports. See link and picture below.
https://patrickmotorsports.com/products/dri...7b3a2&_ss=r $350.00 for the set, shipped in the conus (not including PMS spacers). No on-line (PayPal, etc.) payments. Check or cashier's check please. Attached image(s) |
dug |
Oct 28 2024, 04:01 PM
Member Group: Members Posts: 183 Joined: 26-December 06 From: Santa Cruz, CA Member No.: 7,382 Region Association: Northern California |
914-6 CVs are the same outer dimensions and bolt pattern as 914-4 CVs, but have a different spline count.
So 914-4 CVs/axles will bolt up to a 914-6, the transmission output flanges are the same, which is why you can just bolt in a 914 side-shift trans in a 914-6 too, aside from modifying the linkage. |
Montreal914 |
Oct 28 2024, 05:18 PM
Senior Member Group: Members Posts: 1,684 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
914-6 CVs are the same outer dimensions and bolt pattern as 914-4 CVs, but have a different spline count. So 914-4 CVs/axles will bolt up to a 914-6, the transmission output flanges are the same, which is why you can just bolt in a 914 side-shift trans in a 914-6 too, aside from modifying the linkage. Great explanation! (IMG:style_emoticons/default/sunglasses.gif) |
Lo-Fi Version | Time is now: 1st November 2024 - 04:17 AM |
