Tom1394racing |
Member ![]() ![]() Group: Members Posts: 439 Joined: 25-August 07 From: CT Member No.: 8,039 Region Association: North East States ![]() ![]() |
On my -6 GT project I decided to leave the CV/axle installation until after the engine was installed. I figured there has to be a way to change out the CV/axle assembly with the engine in the car.
This afternoon, I went to install them with the stub axle installed on the CV. It was not clear that they would fit. It seemed like I might need to remove the heat exchanger and/or the shock absorber. Any tricks to this? Do I need to install the stub axles before the CV/axle assembly? I can't imagine that I need to remove the engine to install the CV/axles. How is this done? |
Tom1394racing |
Thanks for all your suggestions. I'll try the passenger install first with removing only the shock bolt and allowing the trailing arm to droop. If I can't get enough clearance that way to fit the stub axle into the trailing arm, I'll remove the heat exchanger.
I wish I had installed the axles before the engine. (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 20th April 2025 - 12:24 AM |
