When was the last time you replaced ALL your fuel hoses?, How long has it been?! |
VaccaRabite |
Oct 30 2024, 10:58 AM
En Garde! Group: Admin Posts: 13,584 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Over the past few weeks I've been replacing my fuel hoses.
Well, it started 2 years ago when I put in the new engine, I decided it was a good idea to replace all the engine bay fuel lines, even though the hoses there had "just been replaced". While doing my brake master earlier this month I chose to pull the gas tank and just do the res hoses on my work bench. Which exposed all my under tank gas lines. Those are still new, right? I replaced those not long ago. 2014? Oh crap those are 10 years old. And what does "new" gas line look like? Mostly fine, except where it had dry-rotted and was weeping fuel. And this was not cheap hose. This was expensive Continental SAE 30r9 injection hose. So I replaced it all. Put the tank back in. Backed the car out into the drive way and just let it idle while I looked for leaks. Found a leak under the engine bay. I forgot about the hoses that went from the center tunnel to the engine compartment hard lines. And while wiggling my tunnel hard line I had opened up a dry rot crack. So I got more 30r9 fuel line and replaced those lines. Now I'm leak free. I bet a LOT OF YOU have fuel lines older then a decade. If you aren't sure, then its time. Replace your fuel lines! Fire is BAD. Zach |
technicalninja |
Oct 30 2024, 11:30 AM
Senior Member Group: Members Posts: 1,951 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
(IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif)
Nother thing to keep in mind... Modern fuel has ethanol. 15-20 years back they were putting MTBE in it. 40 years back they were adding lead. This mish-mash of vastly different additives effects rubber in different ways. It ALSO effects plastic as well. I'm changing all of my lines INCLUDING the plastic puppies in the tunnel because of this. If you're still fuel injected it's MORE important IMO as higher pressure "finds" leaks sooner rather than later. |
Lo-Fi Version | Time is now: 1st November 2024 - 04:17 AM |
