> When was the last time you replaced ALL your fuel hoses?, How long has it been?!
VaccaRabite
post Oct 30 2024, 10:58 AM
En Garde!
Over the past few weeks I've been replacing my fuel hoses.
Well, it started 2 years ago when I put in the new engine, I decided it was a good idea to replace all the engine bay fuel lines, even though the hoses there had "just been replaced".
While doing my brake master earlier this month I chose to pull the gas tank and just do the res hoses on my work bench. Which exposed all my under tank gas lines. Those are still new, right? I replaced those not long ago. 2014? Oh crap those are 10 years old.
And what does "new" gas line look like? Mostly fine, except where it had dry-rotted and was weeping fuel. And this was not cheap hose. This was expensive Continental SAE 30r9 injection hose.
So I replaced it all. Put the tank back in. Backed the car out into the drive way and just let it idle while I looked for leaks. Found a leak under the engine bay. I forgot about the hoses that went from the center tunnel to the engine compartment hard lines. And while wiggling my tunnel hard line I had opened up a dry rot crack. So I got more 30r9 fuel line and replaced those lines. Now I'm leak free.
I bet a LOT OF YOU have fuel lines older then a decade. If you aren't sure, then its time. Replace your fuel lines! Fire is BAD.
Zach
Jack Standz
post Oct 30 2024, 01:53 PM
Last year in the '74.
Replaced with SS Teflon -6AN lines.
Had Chris at Tangerine Racing weld some -6AN connections on his SS tunnel lines and installed those at the same time. Looking for many years of use.
VaccaRabite   When was the last time you replaced ALL your fuel hoses?   Oct 30 2024, 10:58 AM
Freezin 914   :agree: A great reminder! Thank you…. Hop...   Oct 30 2024, 11:23 AM
VaccaRabite   :agree: A great reminder! Thank you…. Ho...   Oct 30 2024, 07:55 PM
bdstone914   :agree: A great reminder! Thank you…. H...   Oct 30 2024, 11:20 PM
VaccaRabite   That is not correct. It is 30R14 hose that is e...   Oct 31 2024, 10:10 AM
technicalninja   :agree: :agree: :agree: :agree: :agree: Noth...   Oct 30 2024, 11:30 AM
VaccaRabite   I'm changing all of my lines INCLUDING the pl...   Oct 30 2024, 08:06 PM
rjames   I'm changing all of my lines INCLUDING the p...   Oct 31 2024, 10:10 AM
SirAndy   When was the last time you replaced ALL your fuel ...   Oct 30 2024, 01:09 PM
mb911   4 years ago for me   Oct 30 2024, 01:24 PM
Jack Standz   Last year in the '74. Replaced with SS Teflon...   Oct 30 2024, 01:53 PM
bdstone914   Gates Baracade fuel line is ethanol compatible. R...   Oct 30 2024, 02:10 PM
flipb   Have not replaced them in 15 years of ownership. ...   Oct 30 2024, 02:42 PM
rjames   It may been too often, but I tend to replace them ...   Oct 30 2024, 03:01 PM
worn   It may been too often, but I tend to replace them...   Oct 30 2024, 07:13 PM
brant   thought of this myself about 4 years back. they we...   Oct 30 2024, 03:20 PM
emerygt350   When I was 20 I got this 1969 Cadillac 2door DeVil...   Oct 30 2024, 03:47 PM
worn   When I was 20 I got this 1969 Cadillac 2door DeVi...   Oct 30 2024, 07:15 PM
rjames   Also... don't use that extra unused fuel line ...   Oct 30 2024, 04:16 PM
aharder   I did mine about 6 years ago when I installed the ...   Oct 31 2024, 02:49 AM
Root_Werks   Two years ago for me. Assembly after paint with n...   Oct 31 2024, 11:01 AM
Geezer914   So what is the recommended life of Gates barricade...   Oct 31 2024, 12:10 PM
rjames   So what is the recommended life of Gates barricad...   Oct 31 2024, 12:51 PM
windforfun   What a coincidence. I had a hose blow out on me j...   Oct 31 2024, 12:51 PM
- Lo-Fi Version Time is now: 1st November 2024 - 04:18 AM
