When was the last time you replaced ALL your fuel hoses?, How long has it been?! |
VaccaRabite |
Oct 30 2024, 10:58 AM
En Garde! Group: Admin Posts: 13,584 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Over the past few weeks I've been replacing my fuel hoses.
Well, it started 2 years ago when I put in the new engine, I decided it was a good idea to replace all the engine bay fuel lines, even though the hoses there had "just been replaced". While doing my brake master earlier this month I chose to pull the gas tank and just do the res hoses on my work bench. Which exposed all my under tank gas lines. Those are still new, right? I replaced those not long ago. 2014? Oh crap those are 10 years old. And what does "new" gas line look like? Mostly fine, except where it had dry-rotted and was weeping fuel. And this was not cheap hose. This was expensive Continental SAE 30r9 injection hose. So I replaced it all. Put the tank back in. Backed the car out into the drive way and just let it idle while I looked for leaks. Found a leak under the engine bay. I forgot about the hoses that went from the center tunnel to the engine compartment hard lines. And while wiggling my tunnel hard line I had opened up a dry rot crack. So I got more 30r9 fuel line and replaced those lines. Now I'm leak free. I bet a LOT OF YOU have fuel lines older then a decade. If you aren't sure, then its time. Replace your fuel lines! Fire is BAD. Zach |
rjames |
Oct 30 2024, 03:01 PM
I'm made of metal Group: Members Posts: 4,132 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
It may been too often, but I tend to replace them every 5-7 years. Usually because I'm 'already in there' doing other stuff.
Double-check your work, too. When I replaced all of the lines earlier this year during a last check before starting the car I found I hadn't put a hose clamp on the line that connects to the pressure regulator. (IMG:style_emoticons/default/unsure.gif) |
worn |
Oct 30 2024, 07:13 PM
can't remember Group: Members Posts: 3,325 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
It may been too often, but I tend to replace them every 5-7 years. Usually because I'm 'already in there' doing other stuff. Double-check your work, too. When I replaced all of the lines earlier this year during a last check before starting the car I found I hadn't put a hose clamp on the line that connects to the pressure regulator. (IMG:style_emoticons/default/unsure.gif) Sounds silly, but is so easy to do. Glad you found it. |
Lo-Fi Version | Time is now: 1st November 2024 - 04:19 AM |
