When was the last time you replaced ALL your fuel hoses?, How long has it been?! |
VaccaRabite |
Oct 30 2024, 10:58 AM
En Garde! Group: Admin Posts: 13,584 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Over the past few weeks I've been replacing my fuel hoses.
Well, it started 2 years ago when I put in the new engine, I decided it was a good idea to replace all the engine bay fuel lines, even though the hoses there had "just been replaced". While doing my brake master earlier this month I chose to pull the gas tank and just do the res hoses on my work bench. Which exposed all my under tank gas lines. Those are still new, right? I replaced those not long ago. 2014? Oh crap those are 10 years old. And what does "new" gas line look like? Mostly fine, except where it had dry-rotted and was weeping fuel. And this was not cheap hose. This was expensive Continental SAE 30r9 injection hose. So I replaced it all. Put the tank back in. Backed the car out into the drive way and just let it idle while I looked for leaks. Found a leak under the engine bay. I forgot about the hoses that went from the center tunnel to the engine compartment hard lines. And while wiggling my tunnel hard line I had opened up a dry rot crack. So I got more 30r9 fuel line and replaced those lines. Now I'm leak free. I bet a LOT OF YOU have fuel lines older then a decade. If you aren't sure, then its time. Replace your fuel lines! Fire is BAD. Zach |
Geezer914 |
Oct 31 2024, 12:10 PM
Geezer914 Group: Members Posts: 1,749 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
So what is the recommended life of Gates barricade fuel injection hose?
rjames |
Oct 31 2024, 12:51 PM
I'm made of metal Group: Members Posts: 4,132 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
So what is the recommended life of Gates barricade fuel injection hose? According to their documentation, shelf life is 3-5 years so don't buy more than you need. There is no specific info on when lines should be replaced after they've been put into use given the numerous variables. Personally, I wouldn't go longer than 5-7 years. Fuel hose has gotten expensive, but replacing the fuel lines is still a lot cheaper than replacing the whole car. Info from Gates: http://www.innoveng.in/Gates%20Hydraulic%20Catalog.pdf |
Lo-Fi Version | Time is now: 1st November 2024 - 04:19 AM |
