> Help - Installing CV/Axle Assemblies after Engine Install?
Tom1394racing
post Oct 29 2024, 02:59 PM
On my -6 GT project I decided to leave the CV/axle installation until after the engine was installed. I figured there has to be a way to change out the CV/axle assembly with the engine in the car.
This afternoon, I went to install them with the stub axle installed on the CV. It was not clear that they would fit. It seemed like I might need to remove the heat exchanger and/or the shock absorber. Any tricks to this? Do I need to install the stub axles before the CV/axle assembly? I can't imagine that I need to remove the engine to install the CV/axles.
How is this done?
Tom1394racing
post Oct 31 2024, 02:17 PM
I did the driver's side today. I only needed to remove the shock, just like the passenger side. A little bit more fiddling on this side. Being able to slide the inboard CV joint towards the middle of the axle on the free-floating axle made a big difference in the clearance.
Thanks again for all the suggestions
- Lo-Fi Version Time is now: 20th April 2025 - 12:27 AM
