Newbie Winter Projects: 1.7L D-Jet Punchlist, TPS and AAR rebuild tips? |
Stev914 |
Oct 31 2024, 10:21 AM
Newbie Group: Members Posts: 3 Joined: 22-July 24 From: Lansing, MI Member No.: 28,254 Region Association: Upper MidWest |
914 Pals:
I'm looking for newbie guidance on a couple of D-Jet related projects. My '72 914-4 is about to take a Winter break in my heated garage. After getting much improved performance by adding a 123 distributor, there are two projects my local mechanic thinks would further improve matters, and I think I might be able to take them on myself (so does he). - Rebuild the Auxiliary Air Regulator (AAR) - Rebuild the Throttle Pressure Sensor (TPS) (e.g. replace the circuit board) I am reasonably handy, but not a car guy. Yet. I think these two projects might be good "gateway" jobs to get more more comfortable. Because I won't be driving the car for a few months, these seem like manageable projects to keep me engaged with the thing. Q. Any tips, tricks or precautions on these two projects? Thanks, Steve --- MORE DETAIL: Here's more info about the car. This '72 has stock D-Jet, and I want to keep it (no plans to go carbs or do anything else). It was originally a 1.7L, but has new AMC heads and is now 1.8L. As I mentioned, I just upgraded to a 123 (4-R-V-IE) distributor. Apart from that, the engine is stock and I really want to keep it that way. The TPS mostly causes issues at about 50% throttle; I've already sort of learned where that is an can avoid it with my foot; that said, now that I am driving it a lot, I can only imagine it will get worse. The idle is also only an intermittent problem, but if I am putting the car away for 3 months, this might be a great time to do the refresh on both units. I realize I could probably just purchase rebuilt units, but this seems like a good way to dip my toe in the water. Please caution me if you think otherwise! I do like tinkering, but have never really worked on cars. For AAR, Ian Karr's great video makes me think I could definitely do it. https://youtu.be/cBdjLrxvBIM?si=xzCHIzgjlDNIaPiz Barefoot Garage Jax video on TPS rebuild also makes me think this is within reach for me: https://youtu.be/chqXHxYFCVw?si=v6S9t5o8J_pZq_D0 Finally, my operational assumption is that rebuilding these two components can't hurt (unless I screw it up some how). Even if they aren't contributing significantly to problems, we could file these projects into the "learning" and "preventative maintenance" categories. |
emerygt350 |
Oct 31 2024, 03:43 PM
Advanced Member Group: Members Posts: 2,473 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
The AAR is not working? Stuck closed?
The TPS is super easy. I seem to remember some mistakes with his rebuild instructions so I wouldn't take it as gospel. It really is so stupid simple you should be fine. Follow the 914rubber instructions with the new board. That said, all you may need to do is clean the contacts on your existing board. |
Lo-Fi Version | Time is now: 1st November 2024 - 04:17 AM |
