> Cutting Out, Bad miss- Help Needed
PDXBob
post Oct 21 2024, 02:30 PM
Frustrated by a Bad Miss. hope the 914World Experts can help me out!
On my 1975 914 (1.8) I have had a sporadic bad miss for the last 6 to 8 months. Here are some of the details.
- it’s been doing this for at least 6-8 months. Some days doesn’t miss at all. But today it was bucking so hard I didn’t know if I’d make it home. This was the worst it’s ever been!
- When it misses it feels like it’s bucking, that is, doesn’t feel like one cylinder miss but total cut out.
- it’s worse under a load, e.g. when going up a steep hill.
- In the driveway today I could rev it up and hold it while standing still with no miss. Didn’t matter if I held it at 2,000, 3,000 revs- didn’t miss.
- not sure if fuel or electric issue. Any tests I could do to determine?
- Does it in all gears.
- The Tac does NOT fluctuate when it cuts out.
- The lights and radio do NOT flicker or stop.
Any suggestions would be greatly appreciated. Thanks in Advance!
PDXBob
PDXBob
post Nov 8 2024, 01:30 PM
Ok, so I checked out my TPS and inspected and fixed a coupe of ground wires. But I still have the bad miss, bucking, cutting out or whatever you want to call it.
One thing that I recently noticed is it seems to be really bad after the engine heats up. So, Clay and Dr914 mentioned ballast resistor and I just ordered one. My thinking is maybe the ballast resistor is breaking down when engine hot.
Is this logical, and is there some other likely cause for bad miss that is affected by heat?
Thx, PDXBob
PDXBob   Cutting Out   Oct 21 2024, 02:30 PM
rjames   When was the last time you overhauled your distrib...   Oct 21 2024, 03:44 PM
PDXBob   When was the last time you overhauled your distri...   Oct 21 2024, 10:16 PM
Olympic 914   I had a similar issue coming back from Okteenerfes...   Oct 21 2024, 04:44 PM
nivekdodge   I had a similar issue coming back from Okteenerfe...   Nov 4 2024, 06:27 PM
technicalninja   :agree: :agree: :agree: Especially if you don...   Oct 21 2024, 05:18 PM
worn   Would it be correct to say that the motor runs smo...   Oct 21 2024, 05:36 PM
PDXBob   Would it be correct to say that the motor runs sm...   Oct 21 2024, 10:10 PM
PDXBob   Thanks all. I’ll start working on various sugge...   Oct 21 2024, 10:12 PM
iankarr   Cutting out like that can be caused by obstruction...   Oct 22 2024, 01:21 AM
PDXBob   Cutting out like that can be caused by obstructio...   Oct 22 2024, 05:28 PM
Fazasport   I am going to speculate that you may have a proble...   Oct 22 2024, 04:46 AM
PDXBob   I am going to speculate that you may have a probl...   Oct 22 2024, 05:31 PM
ClayPerrine   I am going to speculate that you may have a probl...   Nov 5 2024, 06:34 AM
emerygt350   Not sure if the 1.8 has the same TPS as a 2.0... ...   Oct 22 2024, 05:48 PM
Artfrombama   My $.02 Engine missing under load. Classic s...   Oct 25 2024, 10:35 AM
930cabman   My $.02 Engine missing under load. Classic ...   Oct 25 2024, 02:07 PM
nivekdodge   Like Olympic 914, I had a miss I was chasing and c...   Oct 26 2024, 09:19 AM
PDXBob   I’m going through and checking stuff to try and ...   Nov 4 2024, 06:05 PM
brant   Don’t forget to adjust the valves. Set fuel pres...   Nov 5 2024, 10:11 AM
dr914@autoatlanta.com   I would first replace the points condenser and set...   Nov 5 2024, 10:25 AM
PDXBob   Thanks Clay and Dr914. Gives me A few more thing...   Nov 5 2024, 02:42 PM
PDXBob   Ok, so I checked out my TPS and inspected and fixe...   Nov 8 2024, 01:30 PM
JeffBowlsby   Our original engine bay harnesses are 50 years old...   Nov 8 2024, 05:24 PM
Osnabruck914   Every time I have had those symptoms, it was simpl...   Nov 9 2024, 11:51 AM
brant   The fact that you had to repair a few connectors m...   Nov 9 2024, 01:20 PM
brant   Duplicate post   Nov 9 2024, 01:20 PM
PDXBob   I still have the cutting out (bucking) issue and h...   Nov 27 2024, 08:05 PM
8 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 30th November 2024 - 10:36 PM
