Repairing the main seal leak, Finally got to the first part of it. |
mmichalik |
Nov 11 2024, 09:46 AM
MikeM Group: Members Posts: 732 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California |
I was able to get some time this weekend, at the cost of all of the household chores, to pull the motor so I can start repairing the main seal leak.
I was a bit nervous about doing it for the first time but, It was relatively straight forward and much easier then I thought it would be. Hopefully I can get back to the job this weekend so we can button this thing up and I can start driving it again. Thanks to @ChrisFoley for the engine lift plate. Thing worked like a charm! Here are a couple pictures: Attached thumbnail(s) |
JeffBowlsby |
Nov 11 2024, 10:02 AM
914 Wiring Harnesses Group: Members Posts: 8,750 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
While you are in ther you have to at least get a valve adjustment, and what else can you do that will save you time later?
mmichalik |
Nov 11 2024, 10:21 AM
While you are in ther you have to at least get a valve adjustment, and what else can you do that will save you time later? (IMG:style_emoticons/default/wink.gif) Great suggestions. I will do just that. Thanks @JeffBowlsby |
Lo-Fi Version | Time is now: 28th November 2024 - 04:42 AM |
