> CFR Firewall Shifter Bushing, Fasteners
TargaToy
post Oct 30 2024, 04:09 PM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO-
I'm installing Chris Foley's firewall bushing which is a beautiful design.
Has anybody installed one using fasteners other than the sheet metal screws or pop rivets that came with the kit?
I've been contemplating installing #10-24 riv-nuts after reading someone else's experience with either the screws or the rivets (I can't remember which) working loose over time.
What's your experience?
HansJan
post Nov 12 2024, 11:36 PM
TargaToy   CFR Firewall Shifter Bushing   Oct 30 2024, 04:09 PM
Dlee6205   I've installed a couple so far and always used...   Oct 30 2024, 04:54 PM
TargaToy   I've installed a couple so far and always use...   Oct 30 2024, 06:49 PM
jim_hoyland   Ric-nuts sound interesting, tell us what you decid...   Oct 30 2024, 05:06 PM
gereed75   I fabbed a little nut plate to put on the interior...   Oct 30 2024, 05:50 PM
jim_hoyland   I fabbed a little nut plate to put on the interio...   Oct 30 2024, 06:12 PM
gereed75   I fabbed a little nut plate to put on the interi...   Oct 31 2024, 04:58 PM
ChrisFoley   A friend of mine said he installed one with self t...   Oct 31 2024, 06:20 AM
jim_hoyland   What does a drill bit wrapped in tape look like ? ...   Oct 31 2024, 06:42 AM
GregAmy   I am a massive fan of rivnuts, use them in any app...   Oct 31 2024, 07:36 AM
VaccaRabite   I installed the spherical bushing from Chris in 20...   Oct 31 2024, 11:46 AM
Flyinlow   I also used the rivets but used j b weld on back j...   Oct 31 2024, 04:50 PM
FlacaProductions   I also used the rivets but used j b weld on back ...   Oct 31 2024, 06:05 PM
TargaToy   Here's a little follow-up. Picked up a larg...   Nov 11 2024, 12:43 PM
913B   Here's a little follow-up. Picked up a lar...   Nov 11 2024, 08:10 PM
technicalninja   Thanks for posting that! I'll do somethin...   Nov 11 2024, 01:31 PM
Montreal914   This is a very elegant solution to this installati...   Nov 11 2024, 05:42 PM
jim_hoyland   Are the nuts put on through the hole in the firewa...   Nov 11 2024, 08:01 PM
TargaToy   Are the nuts put on through the hole in the firew...   Nov 11 2024, 08:16 PM
jim_hoyland   Thanks: so you reached back from inside the cabin ...   Nov 11 2024, 08:29 PM
Shivers   Thanks: so you reached back from inside the cabin...   Nov 12 2024, 09:43 AM
NARP74   Isn't that new washer defeating the purpose of...   Nov 12 2024, 09:14 AM
technicalninja   Not a chance. Look at his final pics The washer...   Nov 12 2024, 09:26 AM
TargaToy   The only "gotcha" here might be too muc...   Nov 12 2024, 11:38 AM
technicalninja   The only "gotcha" here might be too mu...   Nov 12 2024, 01:19 PM
iankarr   Great idea. That plate is a really nice upgrade to...   Nov 12 2024, 04:36 PM
jim_hoyland   How would the plate compare to using RivNuts ?   Nov 12 2024, 05:30 PM
technicalninja   All other forms of attachment rely on the firewall...   Nov 12 2024, 06:47 PM
TargaToy   Adding to everything @technicalninja said, I als...   Nov 12 2024, 08:27 PM
nivekdodge   Installed one today with the rivets and it went pe...   Nov 12 2024, 08:53 PM
GregAmy   Installed one today with the rivets and it went p...   Nov 14 2024, 06:48 AM
technicalninja   Got me thinking... That washer is ALMOST thick en...   Nov 12 2024, 09:08 PM
HansJan   For those that are on the fence. This bushing rea...   Nov 12 2024, 11:34 PM
VaccaRabite   For those that are on the fence. This bushing re...   Nov 13 2024, 05:32 AM
HansJan   ..   Nov 12 2024, 11:36 PM
jim_hoyland   And, the screws are fed from the inside of the fir...   Nov 13 2024, 01:55 PM
NARP74   And, the screws are fed from the inside of the fi...   Nov 13 2024, 02:08 PM
jim_hoyland   And, the screws are fed from the inside of the f...   Nov 13 2024, 05:54 PM
ChrisFoley   M5 would make more sense than M6, which is oversiz...   Nov 13 2024, 06:46 PM
930cabman   M5 would make more sense than M6, which is oversi...   Nov 14 2024, 05:55 AM
gereed75   Every time this comes up I say the same thing - th...   Nov 14 2024, 08:36 AM
jim_hoyland   :agree: The mechanism resolves most of the linkag...   Nov 15 2024, 09:22 AM
18 User(s) are reading this topic (18 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 28th November 2024 - 04:57 AM
