> Repairing the main seal leak, Finally got to the first part of it.
mmichalik
post Nov 11 2024, 09:46 AM
MikeM
I was able to get some time this weekend, at the cost of all of the household chores, to pull the motor so I can start repairing the main seal leak.
I was a bit nervous about doing it for the first time but, It was relatively straight forward and much easier then I thought it would be.
Hopefully I can get back to the job this weekend so we can button this thing up and I can start driving it again.
Thanks to @ChrisFoley for the engine lift plate. Thing worked like a charm!
Here are a couple pictures:
Superhawk996
post Nov 14 2024, 08:13 AM
(IMG:style_emoticons/default/smilie_pokal.gif) on knowing how to drop the engine / trans / exhaust / muffler as an assembly. This is the easiest way to do it in my opinion.
mmichalik
post Nov 14 2024, 11:33 AM
MikeM
QUOTE(Superhawk996 @ Nov 14 2024, 06:13 AM) *
Thanks! It just seemed like the most logical way to do it.
Now, I just have to wait for parts to arrive. Hopefully I will be able pull things apart and get ready for the new parts this weekend.
mmichalik   Repairing the main seal leak   Nov 11 2024, 09:46 AM
mmichalik   Dropped the engine so I can fix the oil leak   Nov 11 2024, 09:50 AM
JeffBowlsby   While you are in ther you have to at least get a v...   Nov 11 2024, 10:02 AM
mmichalik   While you are in ther you have to at least get a ...   Nov 11 2024, 10:21 AM
rjames   I'd also do the oil cooler seals. Although, ba...   Nov 11 2024, 11:23 AM
JeffBowlsby   Unless you know they are recently changed, if it w...   Nov 11 2024, 02:07 PM
mmichalik   The entire unit, from front to back, has probably ...   Nov 11 2024, 02:56 PM
Jack Standz   When you put the new seal in, this tool helps get ...   Nov 11 2024, 03:25 PM
mmichalik   When you put the new seal in, this tool helps get...   Nov 11 2024, 03:34 PM
930cabman   Might check the trans input shaft also for leakage   Nov 14 2024, 05:58 AM
Superhawk996   :trophy: on knowing how to drop the engine / trans...   Nov 14 2024, 08:13 AM
mmichalik   :trophy: on knowing how to drop the engine / tran...   Nov 14 2024, 11:33 AM
porschetub   :trophy: on knowing how to drop the engine / tra...   Nov 14 2024, 09:12 PM
mmichalik   [quote name='mmichalik' post='3177197' date='Nov ...   Nov 15 2024, 09:18 AM
technicalninja   Raby does case mods to help the RMS housing drain....   Nov 14 2024, 12:29 PM
bkrantz   Welcome to the drop the engine club. If you do it ...   Nov 14 2024, 08:15 PM
930cabman   Welcome to the drop the engine club. If you do it...   Nov 15 2024, 01:40 PM
Superhawk996   Pay close attention to the flywheel sealing surfac...   Nov 15 2024, 11:14 AM
- Lo-Fi Version Time is now: 28th November 2024 - 04:41 AM
