> 914World Classifieds Rules
> FS: Microsquirt kit
Montreal914
post Nov 16 2024, 12:34 PM
For Sale:
Never fired Microsquirt ECU with an array of sensors and components to upgrade your type 4 engine. (IMG:style_emoticons/default/smile.gif)
A while back I had started the Microsquirt conversion of my 2056 but the project got halted by my still on-going (IMG:style_emoticons/default/rolleyes.gif) shell restoration. More recently, I acquired a 3.2 six that I will be using for my build so I am moving on and offering this to the next interested World member! (IMG:style_emoticons/default/smile.gif)
This thread below explains my whole process and where I stood at the time of stopping. A lot of research was done here (IMG:style_emoticons/default/smilie_pokal.gif) and on Shoptalkforums (they have pretty good info there too (IMG:style_emoticons/default/biggrin.gif)) to determine which components to select.
Thread: http://www.914world.com/bbs2/index.php?sho...=342361&hl=
If you are looking at doing this project, I believe this is a good starting point where a chunk of the work has been done. (IMG:style_emoticons/default/smash.gif)
All part listed below were acquired new and prepared/installled per build thread, but never ran. I will refer them as new in my list below unless otherwise indicated.
List of the kit's content:
- New Microsquirt ECU (Dub Shop)
- New Short MS cable harness (Dub Shop)
- New crank trigger wheel, pick up sensor and cracket (Dub Shop)
- New Throttle position switch with custom made adaptor for 2 liter throttle body
- New VW ignition coil pack with custom built bracket
- New Magnecore ignition cables for type 4 custom modified to fit new VW coil pack
- Used BMW air cooled motocycle cylinder head temperature sensor (M10 thread)
- New 1 Bar MAP sensor (intake vaccuum level)
- New 3 Bar MAP sensor (atmospheric pressure monitoring)
- New Resistance pack for stock D-Jet injectors with custom bracket
- New BMW auxiliary air valve with custom mounting bracket
- Used D-Jet air intake temperature sensor
- Custom made block-off plate for plenum auxiliary injector delete
- New CB Performance distributer delete plug
- New relays and fuse block
Price: $575 + shipping (IMG:style_emoticons/default/smile.gif)
Pick up welcome in Claremont or Pasadena
Kit (not everything shown)
Crack trigger wheel
Crank trigger sensor and bracket
Throttle position switch with custom bracket
Ignition coil subassembly
Ignition coil, MAP, and custom bracket
Magnecore cables
BMW cylinder head temp sensor
BMW head sensor installed in stock location on head
1 of 2 MAP sensor
Resistance pack for D-Jet injectors
BMW auxiliary air valve mounted subassembly
Auxiliary air valve subassembly with custom bracket
Distributor delete plug
Cold start injector delete block off plate
GregAmy
post Nov 17 2024, 09:50 AM
Montreal914   FS: Microsquirt kit   Nov 16 2024, 12:34 PM
technicalninja   This is a pretty cool kit! Swap the 3/1 bar s...   Nov 16 2024, 12:47 PM
Montreal914   Thank you Ninja! FYI, Microsquirt is waste sp...   Nov 16 2024, 01:05 PM
bdstone914   @[url=http://www.914world.com/bbs2/index.php?showu...   Nov 16 2024, 01:41 PM
Montreal914   Pending!   Nov 16 2024, 02:30 PM
GregAmy   [b]NOOOOOOOOOOOOOOOO!!!!!...   Nov 16 2024, 04:25 PM
Montreal914   @GregAmy I know :( i was sad preparing this add ...   Nov 16 2024, 05:59 PM
GregAmy   :beer2:   Nov 17 2024, 09:50 AM
- Lo-Fi Version Time is now: 22nd November 2024 - 06:05 AM
