> Help - Strange Oil Pressure Gauge Behavior
Tom1394racing
post Nov 18 2024, 06:17 PM
I am working towards first start on the 3.2 Short Stroke installed in my -6 GT project.
While cranking the engine over with the fuel pumps and MSD disconnected and the spark plugs out, I am getting no oil pressure reading on the dashboard gauge. To verify if I do really have oil pressure, I connected a mechanical gauge in place of the sending unit and cracked open the cam oil line. I got 30 psi on the gauge and plenty of oil leaking from the cam line.
The gauge registered around 30 psi, I just did not capture it in a photo.
So, it seems like the engine is making good pressure while cranking. The problem must be in the sender or in the gauge. To check these, I connected the sender to a variable air pressure source and checked the gauge.
The gauge showed the following readings
Key off, no pressure applied to the sender:
Key on, no pressure applied to the sender:
Key on, 50 psi applied to the sender:
Note the engine was not cranking for this test. All looked good for both the sender and the gauge.
Stay tuned.
sixnotfour
post Nov 18 2024, 09:58 PM
leave mechanical gauge and fire it up....thats what you want.....wiring another day....
Tom1394racing   Help - Strange Oil Pressure Gauge Behavior   Nov 18 2024, 06:17 PM
Tom1394racing   Next, I reinstalled the sender in the crankcase, c...   Nov 18 2024, 06:37 PM
Superhawk996   When cranking the engine, the dial on the gauge...   Nov 19 2024, 07:37 PM
Tom1394racing   When cranking the engine, the dial on the gaug...   Nov 20 2024, 08:15 AM
Superhawk996   When cranking the engine, the dial on the gaug...   Nov 21 2024, 07:56 PM
troth   Have you tried jumping the starter with the key in...   Nov 18 2024, 09:09 PM
sixnotfour   leave mechanical gauge and fire it up....thats wha...   Nov 18 2024, 09:58 PM
930cabman   leave mechanical gauge and fire it up....thats wh...   Nov 19 2024, 11:07 AM
Tom1394racing   leave mechanical gauge and fire it up....thats w...   Nov 19 2024, 02:06 PM
r_towle   For what it’s worth, my 84 911 3.2 registers no ...   Nov 18 2024, 10:26 PM
Tom1394racing   Thanks for all your replies. It seems like there i...   Nov 19 2024, 07:42 AM
mb911   Thanks for all your replies. It seems like there ...   Nov 21 2024, 11:13 AM
rgalla9146   Tom after your early tests the cam supply hollow b...   Nov 19 2024, 01:50 PM
Tom1394racing   Tom after your early tests the cam supply hollow ...   Nov 19 2024, 02:07 PM
Cairo94507   @Superhawk996 That makes complete sense; good inf...   Nov 20 2024, 08:14 AM
sixnotfour   I see your gauge has oil idiot light, you could ad...   Nov 21 2024, 11:30 AM
Tom1394racing   I see your gauge has oil idiot light, you could a...   Nov 21 2024, 04:47 PM
- Lo-Fi Version Time is now: 20th April 2025 - 03:50 AM
