Tom1394racing |
Member ![]() ![]() Group: Members Posts: 439 Joined: 25-August 07 From: CT Member No.: 8,039 Region Association: North East States ![]() ![]() |
I am working towards first start on the 3.2 Short Stroke installed in my -6 GT project.
While cranking the engine over with the fuel pumps and MSD disconnected and the spark plugs out, I am getting no oil pressure reading on the dashboard gauge. To verify if I do really have oil pressure, I connected a mechanical gauge in place of the sending unit and cracked open the cam oil line. I got 30 psi on the gauge and plenty of oil leaking from the cam line. ![]() The gauge registered around 30 psi, I just did not capture it in a photo. ![]() So, it seems like the engine is making good pressure while cranking. The problem must be in the sender or in the gauge. To check these, I connected the sender to a variable air pressure source and checked the gauge. ![]() The gauge showed the following readings Key off, no pressure applied to the sender: ![]() Key on, no pressure applied to the sender: ![]() Key on, 50 psi applied to the sender: ![]() Note the engine was not cranking for this test. All looked good for both the sender and the gauge. Stay tuned. |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,791 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
leave mechanical gauge and fire it up....thats what you want.....wiring another day....
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,044 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
leave mechanical gauge and fire it up....thats what you want.....wiring another day.... (IMG:style_emoticons/default/agree.gif) I always run a mechanical gauge, with an electrical gauge for backup. Could be the sender or the gauge or the wiring. Was it working recently? |
Lo-Fi Version | Time is now: 20th April 2025 - 03:50 AM |
