> 914World Classifieds Rules
> WTB: 1.8 L-Jet Brain
Rob-O
post Nov 21 2024, 04:08 PM
I’d really love for this to be a ‘Want To Borrow’ initially. But ‘Want To Buy’ is certainly okay by me.
My L-Jet is still ‘missing’ at certain times. I’ve checked and replaced tons of parts. I’ve narrowed the timing of the miss down. Starting up the car is fine and settles into a perfect idle. After about 10-15 minutes it develops a miss.
Distributor is a 123. New coil, new temp sensor, checked and cleaned all grounds. No vacuum leaks that I’ve detected. AAR has been checked, TB was rebuilt, all FI wiring was checked for continuity before installing several years back. AFM was changed out to a known good unit (thanks @clayperrine ). I feel like I’ve checked everything except changing out the brain. And since the brain can’t be easily bench tested I thought I’d reach out here to see if someone had one laying around.
ClayPerrine
post Nov 21 2024, 09:55 PM
Rob,
I have a few laying around here. You may borrow one if you need to test yours.
Also, did you check the wires on the dropping resistors? They break from vibration and may sometimes cause an intermittent miss.
Clay
9 User(s) are reading this topic (9 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 24th November 2024 - 11:57 AM
