> Eric's Six Conversion, chassis work has finally commenced.
Detroit
post Mar 22 2021, 08:20 PM
Greetings all...
As the title suggests, I'm undertaking a six cylinder heart transplant on my four cylinder '74 914. I've always wanted to build a hot rod of some sort, and a 3.X 914 seems a pretty solid choice. I just hope the patient and donor organ both survive the surgery...
The motor is a 3.0L out of an '82 SC. It needs rebuilding. I'm going to start a separate thread for that over on the Pelican forum in the engine rebuilding section, because I'm going to need lot's of advice. I realize that there are plenty of peops here who've built sixes, but as that forum is dedicated purely to the task it makes sense to me to start the thread there. I'll paste a link for anyone interested once I've got it started. It's not going to be some crazy race motor. I just want a good reliable street engine. I'm not a hundred percent sure what I'm going to do with the chassis at this point, but I have plenty of time to think about it. I work slow.
The overall plan is to rebuild the motor, and then get it running on a start cart, which I've already started to cobble up. At that point I'll pull the four cylinder, do any chassis mods, and stick in the new engine. It all sounds so simple when I type it... Stupid brain.
I've already torn the engine down to the long block, but have paused to get a few things around the garage cleared up. There will be additional pauses along the way. I've got a zillion things to do around here... I'm pretty determined to get this done though, so hopefully said pauses will be brief.
I will do my best to keep everyone updated along the way. And of course supply plenty of pictures. Here's a few to start.
EDIT - Here's a link to the engine build thread:
https://forums.pelicanparts.com/911-engine-...3-0l-build.html
The car.
The six.
The start cart (and mock up engine and trans).
Montreal914
post Nov 22 2024, 12:16 PM
Good looking tub! (IMG:style_emoticons/default/smile.gif) I will be watching and following along your build.
As for 911 A arm, no they do not have the same splines as the 914.
Best to find a good set of 914 A-arms with the U tabs for the sway bar. BTW, stock torsion bars are typically worn due to rubber bushings deformation and bars rubbing. (IMG:style_emoticons/default/dry.gif)
Out of five sets I had, only one was good... (IMG:style_emoticons/default/sad.gif)
Keep on posting!
Detroit   Eric's Six Conversion   Mar 22 2021, 08:20 PM
914Sixer   Way cool. Engine cart is a excellent start. Grea...   Mar 22 2021, 08:26 PM
Superhawk996   Can’t wait to see this come together :headbange...   Mar 22 2021, 08:44 PM
Root_Werks   Look how nice that looks! My 914-6 conversion...   Mar 22 2021, 09:15 PM
mb911   Looks great.. a better start then mine was   Mar 23 2021, 05:27 AM
Detroit   Thank, fellas. And, Phil, consider this start cart...   Mar 23 2021, 05:40 AM
Detroit   Ben, that's your muffler hanging off the back ...   Mar 23 2021, 05:47 AM
mb911   Ben, that's your muffler hanging off the back...   Mar 23 2021, 07:39 AM
Detroit   Absolutely they will fit. You may have to enlarge...   Mar 23 2021, 07:51 AM
mepstein   Absolutely they will fit. You may have to enlarg...   Mar 23 2021, 08:31 AM
CptTripps   Looks like you're off to a great start. Can...   Mar 23 2021, 05:50 AM
Dion   What a fantastic combo. Good luck. You look to hav...   Mar 23 2021, 06:21 AM
Mark Henry   Good start. :thumbsup: You might like to look at ...   Mar 23 2021, 06:22 AM
gereed75   Not Ben, but I will chime in with my experience- t...   Mar 23 2021, 06:53 AM
Cairo94507   Excellent project and a great starting point. You...   Mar 23 2021, 07:48 AM
roblav1   On heat exchangers, it's easier if you can att...   Mar 23 2021, 03:12 PM
Detroit   Thanks for all the input. I'm not at all worr...   Mar 24 2021, 07:12 AM
Mark Henry   Thanks for all the input. I'm not at all wor...   Mar 24 2021, 07:35 AM
Detroit   I haven't gotten anything else done on the sta...   Mar 30 2021, 05:06 PM
Detroit   Well, it's about time I drag this thread out o...   Nov 22 2024, 11:47 AM
Detroit   The car has also undergone a bit of lightening... ...   Nov 22 2024, 11:52 AM
Montreal914   Good looking tub! :) I will be watching and ...   Nov 22 2024, 12:16 PM
930cabman   :popcorn: going to be a great project   Nov 22 2024, 03:44 PM
rjames   Agree with Montreal914 that the original sway bars...   Nov 22 2024, 04:23 PM
Detroit   Thanks for the input, fellas. I will do my best t...   Nov 25 2024, 07:54 AM
rick 918-S   That's a lot of Dirt! :blink: Nice projec...   Nov 26 2024, 06:39 AM
Detroit   I just love picking stuff up from the plater!....   Nov 27 2024, 11:20 AM
Detroit   Okay, I could use a bit of help, please... I'v...   Dec 2 2024, 01:27 PM
davep   If you have removed the clip in the groove at the ...   Dec 2 2024, 02:08 PM
Detroit   Never mind, thanks. I just found the tech article...   Dec 2 2024, 02:22 PM
15 User(s) are reading this topic (15 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 4th December 2024 - 08:44 PM
