> Fuel pump relocation and wiring
captjm
post Nov 22 2024, 09:03 PM
I need some help with wiring a 914 fuel pump being relocated to the front fuel tank location exactly like the 75/76 914's. The car is a 1971 914/4 being set up for a carbureted 2.4 six cylinder. My question is about where to pick up the power to run the pump correctly.
I would like it to have any relay protections like the original if that is the way it is suppose to be. I think the positive power is to come from the engine compartment relay board from the forward connector pin 13? I plan on running the positive wire from pin 13 under the driver side rocker panel forward to to the fuel tank bay and picking up the ground from the closest grounding point nearest to the tank bay. Any comments or advice would be helpful. Thank you
dtmehall
post Nov 22 2024, 09:38 PM
it was 12 gauge for the fuel injection pump. i would suspect that whatever pump you are using for carbs, will draw far fewer amp. hence a lower gauge wire requirement
6 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
1 Members: dtmehall
- Lo-Fi Version Time is now: 24th November 2024 - 07:51 PM
