Fuel pump relocation and wiring |
captjm |
Nov 22 2024, 09:03 PM
Newbie Group: Members Posts: 8 Joined: 28-January 07 From: Temecula, CA Member No.: 7,485 |
I need some help with wiring a 914 fuel pump being relocated to the front fuel tank location exactly like the 75/76 914's. The car is a 1971 914/4 being set up for a carbureted 2.4 six cylinder. My question is about where to pick up the power to run the pump correctly.
I would like it to have any relay protections like the original if that is the way it is suppose to be. I think the positive power is to come from the engine compartment relay board from the forward connector pin 13? I plan on running the positive wire from pin 13 under the driver side rocker panel forward to to the fuel tank bay and picking up the ground from the closest grounding point nearest to the tank bay. Any comments or advice would be helpful. Thank you |
North Coast Jim |
Nov 24 2024, 08:22 AM
Member Group: Members Posts: 331 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
I ran the wire thru the tunnel wired as above. Bought a 2 conductor, red/blk paired wire from West Marine. It had a jacket around the pair, white in color, similar to Romex. Worked great. Oh and the stranded conductor count was IFRC was 19.
Lo-Fi Version | Time is now: 24th November 2024 - 07:37 PM |
