> Injectors and Dejection, Bought the Standard Motor Products Version - Does not fit
ctc911ctc
post Nov 25 2024, 08:54 AM
'74 2.0 25K miles, all original, all rebuilt
All,
I am chasing the final item on this car, occasional firing miss. At idle and at speed the car occasionally misses, does not terribly effect driving but does effect my peace of mind....
I removed, while idling, each of the injector wires (new harness - thank you Bowsley) and the #1 wire had very small effect on operation. Also, the injector looked a bit weepy, gas leaking around the green plastic.
While I was rebuilding the car, all of the injectors were sent to a Bosch guy here in Mass, who has the correct testing equipment. I also bought an additional set on EBAY and sent the originals plus the purchased injectors to him, 7 came back within calibration, one was DOA. (IMG:style_emoticons/default/dry.gif)
Yesterday the fun began. I replaced the #1 injector with one of the rebuilt ones, it leaked......then I tried another.......it also leaked....... (IMG:style_emoticons/default/blink.gif)
THEN, I tried a new injector I purchased from a reseller, it is manufactured by Standard Motor Products and is listed as compatible with the '74 914 2.0. (IMG:style_emoticons/default/drooley.gif)
1. The hose is pressed onto the injector so I had to try and use it instead of my hoses. (IMG:style_emoticons/default/sad.gif)
2. The hose is too short, making the installation difficult (IMG:style_emoticons/default/headbang.gif)
3. The ID of the hose is too small so it was a force fit. (IMG:style_emoticons/default/headbang.gif)
4. the Spray part of the injector is too short and also narrower than the original (IMG:style_emoticons/default/mad.gif)
5. the fit on the manifold tube is not tight, (I had to make a gasket since the ones I had for the other injectors - all new gaskets- were too small
(IMG:style_emoticons/default/dead horse.gif)
I gave up on the new injector and re-installed the old one......
Here is the question:
Has anyone had luck with these injectors, if so, did you cut off the hose? Are you concerned about the loose fit?
Last, perhaps there is another manufacturer that I did not find that you can direct me to?
Thank you Teeners!
emerygt350
post Nov 27 2024, 01:51 PM
Are you sure you have fj67s? For me it was complete plug and play when I installed them.
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 4th December 2024 - 08:35 PM
